Hp No Power Up Issue
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    I am having and issue with two different Hp PC's. One is a core I5. The other has the AMD Vision four core cpu. When the power button is pushed these units will not power up. I have gotten these things to start working again by doing the following things. First unplug the A/C core. Then I disconnected both plugs from the PSU to the main board. I then held the power button down for a few seconds to discharge the MB caps. Then I pluged everything back in and the PC's booted as normal. Could this be caused by a low cmos battery? Both of the units are three years old or so.
    Mark Twain
    John Paul Jones
    Rod Serling
  • c_hegge
    • Sep 2009
    • 5219
    Re: Hp No Power Up Issue
    Nope. The only thing that will happen if the CMOS battery goes flat is that it will start losing the date and time and other BIOS settings. It never stops the PC from POSTing or powering on (at least for 99.99999% of motherboards). It might be the PSUs. Or possibly something else with the motherboard.
      • 31161
      your a bit off with that number, a pretty large number of modern intel boards need the battery to start.
      that said, once it does start, you can check the battery voltage in the bios.
      it may not be acurate, but it will be enough - if the battery is under 2.5v in the bios it's done.
      infact under 2.9 and it's going fast.
      • c_hegge
        • Sep 2009
        • 5219
        I haven't seen a board that won't POST without the battery installed - including plenty of Intel boards.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          What PSU's are in them?
            • 31161
            try some of the ATOM based boards.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Huh, never seen this before. Well, Intel has done it again!
              What power supplies are in these? I think you should check the 5v standby voltage to see if it is good.
              Muh-soggy-knee
              • Junk Parts
                Court Jester
                • Jun 2006
                • 8953
                I can't do anything right now. The PC is 85 miles away from me and I'm sick with the flu anyway. I need to be feeling better before I go down there and tackle her POS.
                Mark Twain
                John Paul Jones
                Rod Serling
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • justice171
                  Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                  by justice171
                  I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                  Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                  1. Verified that all critical voltages are present:
                    • 3.3V and 5V are always present if DC is plugged.
                    • 1.8V on the BIOS chip is present.
                  2. Checked the power button functionality:
                    • When pressed, the voltage drops to 0V, indicating the button is functional.
                  3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                    • Confirmed connectivity is intact, ruling out issues
                  11-26-2024, 12:39 AM
                • claws77
                  lenovo flex 5 14itl05 power sequence issue
                  by claws77
                  hi guys, my motherboard will not start no matter what
                  when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                  but rest nothing happens no sign of life.
                  this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                  with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                  but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                  i have no knowledge of motherboards ....
                  10-20-2024, 02:48 PM
                • yaya3gmax
                  Laptop Power Issue – Works on Battery, Fails on Adapter Load
                  by yaya3gmax
                  Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                  Symptoms:
                  • Laptop works normally on a pre-charged battery.
                  • Battery does not charge when adapter is connected.
                  • Without battery:
                    • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                    • Speakers “pop” when power cut occurs indicating harsh sutdown.
                    • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                  08-21-2025, 07:16 AM
                • Soulzink
                  Samsug washing machine. Power supply DC41-00189a board issue
                  by Soulzink
                  I am trying to fix a samsung washinmachine power supply main board.
                  I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                  Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                  The power supply board reference is the following: DC41-00189a
                  I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                  04-19-2025, 06:26 AM
