iMac a1224 Power Supply ADP-17AF B Schematic
  • magneh
    • Apr 2014
    • 615
    • Portugal
    Hello!
    A friend of mine fried his iMac's PSU when connecting an old monitor.
    The price and availability of this PSU made him ask me to take a look.
    Does anyone have this schematic?
    Model : ADP-170AF B
    Thanks!
    Re: iMac a1224 Power Supply ADP-17AF B Schematic
    DELTA ADP-170AF.
    http://www.ebay.com/itm/Apple-20-iMa...item3a9382f8e9
    Did some one work on it before? I see the two rectifiers are missing.
    Is it completely dead? Do you get any DC right at the two legs of the main filter cap in the primary side, this power supply also has PFC Voltage booster circuit.
    • magneh
      • Apr 2014
      • 615
      • Portugal
      Originally posted by budm
      DELTA ADP-170AF.
      Yes, sorry, gonna correct it.
      Model : ADP-170AF B
      The board was as new, it was me
      Removed just one of them, the other is just lifted up.
      They are stps3045ct .
      thought both had 2 junctions shorted (the 2 outter legs), but the one I removed seemed good out of the board, and both outter pads read shorted without rectifier on place.
      Gonna put in on his place if I get schematic.
      Gonna try tomorrow to supply power to it and mesure DC on the black big capacitor right? between the two pins of the cap.
      Just to be sure to mesure the right thing...
      Thanks!
        They are Common Cathode Rectifier that are connected in parallel for half wave rectifier circuit that is why the two outer pins are tied together.
        "Gonna try tomorrow to supply power to it and mesure DC on the black big capacitor right? between the two pins of the cap" That is correct.
          BTW, can you read the P/N on the SMD ICs: IC31, IC32?
          • magneh
            • Apr 2014
            • 615
            • Portugal
            Ok.So they are OK. gonna put him on his place.
            Check. Gonna try to feed the unit tomorrow and post DC result.
            IC31 - DAP017
            PAF726G
            IC32- DAP015D
            9083724
            So I made also some more mesurings and here are the results I collected.
            I took some pics identifying the components I mesured , still they dont match the PCB markings, cause some of them arent at sight.
            D1 - 0.7
            D2 - shorted both ways
            Q1 - outter 2 contacts shorted both ways
            with COM on middle contact, present 0.7 to both outter contacts.
            Q2 - outter 2 contacts present 1.3 one way and reverse open.
            with COM on middle contact, present 0.88 to the right contact and open to the left contact (following the contacts in the photo)
            Q3 and Q4 presented the same readings and seemed all good.
            Now , should I remove D2 and see if the short is gone on Q1?
            If not remove Q1 and test it?
            Thanks again!
              "Now , should I remove D2 and see if the short is gone on Q1?
              If not remove Q1 and test it?" I would remove them and test them off the board. Any one with suspicious readings I would remove and test it off the board.
              By the way, did the main fuse blow?
              • magneh
                • Apr 2014
                • 615
                • Portugal
                Nope, the fuse is OK.he didnt blew.
                Gonna test them out off the board.
                • magneh
                  • Apr 2014
                  • 615
                  • Portugal
                  Lifted 1 contact of D2 and he reads good off the board... 0.85 one way and open the opposite.
                  Q1 is still shorted both ways on the outter contacts ...
                  gonna remove it tomorrow...too tired
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                    by sam_sam_sam
                    07-01-2024, 06:34 AM
                  • JimBanville
                    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                    by JimBanville
                    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                    09-13-2023, 07:21 AM
                  • Russ1
                    Starlink GEN2 Router Internal Power Supply Chicony UTP-211C Schematic
                    by Russ1
                    Sick of seeing big numbers of these routers dead no power light underneath.....
                    Chasing Schematic of this power supply I have searched high and low....
                    Already spotted a few swollen caps, but Ac fuse ok.....
                    This is a dual output 50Vdc 2.5A and 12Vdc 1.25A psu
                    Can anyone help with any type of schematic and parts list ?
                    Thanks and Regards, Russ
                    07-10-2025, 11:01 PM
