Is what I have compatible with this Delta DPS-250AB power supply?
  • Justin_D33
    Justin
    • Sep 2025
    • 5
    Hello all. This is my Delta DPS-250AB PSU. It does not work anymore, and I'm assuming the cause is dried-out secondary capacitors. Specifically, those dreaded CapXons. I have some recap stock I salvaged from a dead ECS 945GCT-M3:
    1, United Chemicon KZG 560 µF 6.3V, there's one of these
    2, Sanyo WG 2200 µF 10V, there's 3 of these that came from the VRM area
    3, more Sanyo WGs, these came from the PCIe area. There's 3 in total, they are 6.3V ones. I forgot the exact capacitance, and I don't want to dig them out right now.
    • 31246
    slow down.
    is the 5v standby dead?
    if it is then you need to check the fuse and any small caps on the primary side.
    • Justin_D33
      Justin
      • Sep 2025
      • 5
      The fuse is good, last time I checked it looked fine, but 5VSB could very well be dead. I don't know, because this PSU hasn't been powered in almost a year and I can't check. Next time I get a chance, I will.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5059
        • New Zealand
        "Does not work" could mean a lot of things, but I assume you mean "Doesn't turn on"
        If it does not power up at all, you need to look deeper than just capacitors (probably).
        Start with checking if you have 5VSB rail and go from there.
        While bad capacitors on the 5VSB could mean the voltage is too low to start the rest of the supply up, it's far from the only possibility.
        -David VanHorn
        • Justin_D33
          Justin
          • Sep 2025
          • 5
          Okay so I checked and the 5VSB rail is missing, I'm getting 0V when I probe the purple + black wires. I was doing some testing, the diodes are fine, but I could not for the life of me relocate that stupid fuse. So I couldn't check it. But, I did measure the voltage from the primaries and there was absolutely no charge in them whatsoever. So that either means bad 5VSB or a bad MOSFET somewhere, it could even be the fuse.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5059
            • New Zealand
            If you have no voltage on the primary capacitors, you have an open circuit component on the mains input somewhere.
            Likely the fuse, but could also be the bridge rectifier. In rare circumstances the common-mode choke may fail open.
            Sometimes the NTC thermistor fails but again, not often.
            Can you take more photos showing the board and we can find where the fuse is. It will have one somewhere.
            If the fuse is blown you probably have shorted primary side components somewhere, yes.
            -David VanHorn
              by sam_sam_sam
              03-31-2024, 02:12 PM
              MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
              This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-07-2024, 03:40 AM
            • Gentian
              Please help me find 7 pin smd ic 901 part number in Delta DPS-300AB-76 LED Display Power Supply
              by Gentian
              I have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
              09-27-2025, 11:03 PM
            • dragon3x
              >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
              by dragon3x
              Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
              that is still quite new, as it worked OK for some months until it failed.
              At the time I was not into power supply electronics; it was put
              aside and a new power supply installed inside the computer. Also at the time
              power supplies were half the price of today's.
              On the PCB there are a D339 and 7500B chips.
              I have found that schematics with these 2 chips (see included file).
              Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
              Some measurements,...
              06-05-2024, 03:34 PM
