Is what I have compatible with this Delta DPS-250AB power supply?
  • Justin_D33
    Justin
    • Sep 2025
    • 22
    Hello all. This is my Delta DPS-250AB PSU. It does not work anymore, and I'm assuming the cause is dried-out secondary capacitors. Specifically, those dreaded CapXons. I have some recap stock I salvaged from a dead ECS 945GCT-M3:
    1, United Chemicon KZG 560 µF 6.3V, there's one of these
    2, Sanyo WG 2200 µF 10V, there's 3 of these that came from the VRM area
    3, more Sanyo WGs, these came from the PCIe area. There's 3 in total, they are 6.3V ones. I forgot the exact capacitance, and I don't want to dig them out right now.
    • 31304
    slow down.
    is the 5v standby dead?
    if it is then you need to check the fuse and any small caps on the primary side.
    • Justin_D33
      Justin
      • Sep 2025
      • 22
      The fuse is good, last time I checked it looked fine, but 5VSB could very well be dead. I don't know, because this PSU hasn't been powered in almost a year and I can't check. Next time I get a chance, I will.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5096
        • New Zealand
        "Does not work" could mean a lot of things, but I assume you mean "Doesn't turn on"
        If it does not power up at all, you need to look deeper than just capacitors (probably).
        Start with checking if you have 5VSB rail and go from there.
        While bad capacitors on the 5VSB could mean the voltage is too low to start the rest of the supply up, it's far from the only possibility.
        -David VanHorn
        • Justin_D33
          Justin
          • Sep 2025
          • 22
          Okay so I checked and the 5VSB rail is missing, I'm getting 0V when I probe the purple + black wires. I was doing some testing, the diodes are fine, but I could not for the life of me relocate that stupid fuse. So I couldn't check it. But, I did measure the voltage from the primaries and there was absolutely no charge in them whatsoever. So that either means bad 5VSB or a bad MOSFET somewhere, it could even be the fuse.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5096
            • New Zealand
            If you have no voltage on the primary capacitors, you have an open circuit component on the mains input somewhere.
            Likely the fuse, but could also be the bridge rectifier. In rare circumstances the common-mode choke may fail open.
            Sometimes the NTC thermistor fails but again, not often.
            Can you take more photos showing the board and we can find where the fuse is. It will have one somewhere.
            If the fuse is blown you probably have shorted primary side components somewhere, yes.
            -David VanHorn
            • Justin_D33
              Justin
              • Sep 2025
              • 22
              Well, I didn't check it while plugged in, but I did check right after unplugging and there was almost 0V. There's definitely a shorted or open component, possibly a MOSFET, the fuse, or something similar.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5096
                • New Zealand
                You're going to have to check the 5vSB rail while it's plugged in, measuring it after you unplug it isn't going to tell you much of anything useful.
                We need to know for sure if the 5vSB is running or not, because that determines the next stage of troubleshooting.
                -David VanHorn
                • Justin_D33
                  Justin
                  • Sep 2025
                  • 22
                  I checked the 5VSB while plugged in and it was completely dead, right after unplugging I checked for charge in the primaries and there was nothing.
                  • Justin_D33
                    Justin
                    • Sep 2025
                    • 22
                    I hadn't even waited 5 minutes after unplugging and there was literally nothing coming from the primaries, I think there was like 0.4V.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5096
                      • New Zealand
                      Okay, so definitely no 5v standby and it looks like nothing on the primary capacitors either.
                      So now you have to find out why they have no voltage getting to them.
                      So you need to start checking the primary side input circuit and tracing through from the AC inlet to the primary capacitors.
                      Quite possibly you have a blown fuse but a blown open bridge rectifier could also cause this problem.
                      If you do have a blown fuse, then check all the primary side components (including capacitors) for shorts.
                      Post some more photos please, and we can find out where the fuse is...
                      -David VanHorn
                      • Justin_D33
                        Justin
                        • Sep 2025
                        • 22
                        I don't think it's a blown fuse, the supply at least tried to charge the 5VSB, I think there was like 0.12V. More likely the bridge rectifier or caps.
                          • 31304
                          post a good picture of the primary side of the board.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5096
                            • New Zealand
                            Well, you can make as many guesses as you like but you won't know for sure until you actually get the thing out and start doing some tests.
                            Do you need help on how to do that?
                            You said earlier you didn't know where the fuse was - that doesn't matter straight away.
                            If the PSU has a power switch, make sure that's in the ON position, then check continuity from the live and neutral pins of the AC input to the AC pins on the bridge rectifier.
                            You should get continuity on each side. If one is open, you likely have a blown fuse.
                            As stj says - more photos! these will help immensely.
                            -David VanHorn
                            • Justin_D33
                              Justin
                              • Sep 2025
                              • 22
                              I'm starting to be suspicious of the 5VSB startup cap, I did some more tests and there's 120V at the AC side, so it's not the fuse.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 5096
                                • New Zealand
                                So you have 120V AC at the input to the bridge rectifier?
                                You should have about 170V DC coming out - do you get that?
                                No sense worrying about the 5vSB startup circuit until you know it's actually getting power.
                                -David VanHorn
                                • Tynan Dill
                                  by Tynan Dill
                                  Assuming...
                                  11-22-2024, 01:46 PM
                                  03-31-2024, 02:12 PM
                                  MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                                  This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-07-2024, 03:40 AM
                                • Gentian
                                  Please help me find 7 pin smd ic 901 part number in Delta DPS-300AB-76 LED Display Power Supply
                                  by Gentian
                                  I have a 5V 55A led Delta power supply with no output. I found this 7 pin IC 901 damaged as in the photo. All other elements look ok. I checked and every other surrounding componets diodes, resistors and capacitors look ok. I have 2 identical power supplies removed from a led wall which have the same defect with this ic burned but not a working one for reference. I founded by measurements that pin 7 goes to positive hot 450V 220uF electrolytic capacitor primary side. Pin 1, 2, 3, 4 connected together to pcb cooper trace. These four pins goes to negative side of 10uF 50V electrolytic capacitor...
                                  09-27-2025, 11:03 PM
                                • dragon3x
                                  >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
                                  by dragon3x
                                  Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
                                  that is still quite new, as it worked OK for some months until it failed.
                                  At the time I was not into power supply electronics; it was put
                                  aside and a new power supply installed inside the computer. Also at the time
                                  power supplies were half the price of today's.
                                  On the PCB there are a D339 and 7500B chips.
                                  I have found that schematics with these 2 chips (see included file).
                                  Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
                                  Some measurements,...
                                  06-05-2024, 03:34 PM
