Dead corsair VS450 with blown TNY chip (cwt)
  • zunasthegreat
    • Dec 2017
    • 89
    • EU
    I have this Corsair VS450 PSU which lies dead and has an exploded TNY chip. Upon removing primary side parts like mosfets, the bulk cap and the bridge rectifier I've found that the primary cap is also a goner. (Photos)
    The mosfets and the diode are fine and survived the collapse it seems. The TNY chip is shattered and from the online review/sources it was probably a TNY176~177.
  • CapLeaker
    Leaking Member
    • 8229
    Very typical failure.
    • zunasthegreat
      • Dec 2017
      • 89
      • EU
      Around the TNY chip there are 4 caps, 2X 220uF 35V and 2X 10uF 50V. All junk JUN-FU WG showing horrible reading. I replaced the 220uF ones with ZLH 220uF 35V and the 10uF ones with Nichicon SV 10uF 35V. Changed all the secondary ones too from Capxon/Aishi/JunFu into ->
      3.3V - 2X KY 2200uF 10V
      5V - KY 2200 10V + KY 1000uF 16V
      12V - 2X Rubycon ZLH 1800uF 16V (*no space for more than 10mm. Old were Capxon KF 2200uF 16V)
      -12 - Rubycon ZLH 330uF 16V (who uses 1000uF caps here?)
      5VSB - Nichicon HV 1500uF 16V + Nichicon PW 1000uF 10V
      PG Cap near sitronix chip - Nichicon PW 1000uF 10V here
      For the TNY chip I've placed a socket which I don't know if its a good idea cause the IC seems to need the pcb for heat dissipation. The new chip is a TNY178 and I've added a small heatsink on top. For bridge rectifier I used the PBU805 and I also changed the mosfets. The PFC one is a K3568 and the main switchers are now 2X K3569 which I had in stock. These are small updates 8A->10A (main) 10A->12A (PFC).
      Well the psu *works*!!! even with that 100uF 400V cap! New cap will arrive soon and I'll do more testing. No room for more than 25mm diamater for the primary cap.
      • CapLeaker
        Leaking Member
        • 8229
        I see you done a full blown upgrade. What did you order to replace the main filter cap with?
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • double_DD
          How can I be sure that my EC chip is dead?
          by double_DD
          As the title suggests, how can I be sure that my EC chip is really dead?
          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
          03-12-2025, 07:47 AM
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
          by SMDFlea
          Bad...
          09-02-2021, 04:40 PM
        • iyas132
          Corsair RM 750 blown schottky diode near ES1DF
          by iyas132
          Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
          Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
          My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
          Can anyone help me identify the component...
          12-30-2024, 01:34 AM
