Current limit on ATX molex lines?
  • mathog
    • Mar 2010
    • 2655
    I tried to run a fan (with a built in control board) with the 12V from a 4 pin ATX molex connector. The fan has a PWM input and that wasn't attached, so it should not have tried to start. Nevertheless, as soon as the molex was plugged into it the power supply shut down. Presumably the fan was drawing too much current. The fan works if plugged into its normal driver, as far as I can tell it is working normally. I have no idea how much current that fan normally draws, it comes out of a car. It is a squirrel cage about 6" in diameter and 1" thick.
    How much current must that fan have pulled to cause the ATX to shut down?
    I can cut up the ATX supply to get 12V from other places. Is it worth trying all the auxiliary connectors, or should I just cut up the main connector?
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Current limit on ATX molex lines?
    Yesterday I had a similar experience with motor taken from a hard drive, which I assume now is PWM driven. I connected it to 12v from a drive connector on a small ATX PSU I use for bench experiments, and it did a short wiggle and stopped. Removing the 12v had a nice little spark to it. I was able to do this three times, trying different wire combos with the 3 leads on the drive until the PSU shut down on the 3rd attempt. Once allowed to cool the PSU is working as before so hopefully no permanent damage to it.
    Does the PSU have the current or power ratings for the various output voltages printed on it? In my case the +12v output of the PSU I used is rated at 4 Amps.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      For a 500 W PSU, that would have to be close to 40 amps. lol
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
        • 31304
        it's not the amount that causes the shutdown, it's the sudden spike.
        i used to have this problem powering my dremel type tool from an ATX supply and sometimes turning the drill off would trip the psu.
        • mathog
          • Mar 2010
          • 2655
          It does and it is 16A total for +12V. That would be split across the 5 yellow lines coming out of the case. It doesn't say what the over current protection is on a single +12V line. In another forum somebody had measured the maximum constant current the fan draws at max speed, and it was under 2A. However, they did not measure the power on draw, so stj may be onto something about the initial spike being too high.
          The ATX power supply is a Sparkle Power International FSP300-601U.
          • mathog
            • Mar 2010
            • 2655
            Found this reference (but not yet the sources it references):
            http://brazenartifice.wordpress.com/...2v-regulation/
            I've read that some ATX power supplies will shut down completely if too much current is drawn from the 12 volt lines without at least an amp drawn from the 5 volt line too. From first-hand reports, that tends to happen part-way through long prints. I'm pleased to think that shouldn't happen to me.
            That would fit what happens pretty well. Maybe I should just look for a 12VDC wall wart, those things should not be nearly as picky.
            • SteveNielsen
              Retired Tech
              • Jun 2012
              • 2327
              All the +12v yellow wires are connected to the same place in the PSU. There's no "splitting" of the current with only one device connected.
              In my personal experience it was not the initial spike that shut the PSU down, if that were the case it would have happened immediately. That is not to say it could not happen or never happens that way, it just did not for me.
              • mathog
                • Mar 2010
                • 2655
                Useful info, thanks.
                This is making less and less sense. I had two junk 1.34A 12V fans. The connectors were cut off both of the junk fans, they were wired in parallel, and then attached to the same Molex connector. When the power supply started they both spun up and the power supply stayed on. This is without adding a 5V load resistor. That's 2.7A and not even a hiccup. Replaced one of the connections with a probe and touched it and released it a few times. Nice spark each time, and no complaints from the PS.
                As far as we know the fan in the car only pulls 1.6A when it is going full bore. We don't know what it pulls when the car first comes on, that initial current spike could be quite large so long as it was of short duration. It isn't like the car battery is going to care about another couple of amps for a millisecond or two. (The wires connecting the fan in the car's harness are pretty small, maybe 20 or 22 gauge, so clearly there is not much current going through them normally.) The power supply must care about this startup current though, which is why it shuts off. The fan in the car is working normally when its +12V and pulse control come from the car.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  I dunno if there's a thing as finicky as the GFCI hooked up to the washer in the room off the kitchen.....
                  Arc A770 16 GB
                  • SteveNielsen
                    Retired Tech
                    • Jun 2012
                    • 2327
                    The 1.34A 12V fans are not pulse driven though, are they?
                    I am not greatly knowledgeable about PWM motors but my guess is when applied a steady 12v across the phase coils of the motor it is unable to convert the energy to motion and drew too much current from the PSU. I think in a PWM motor the pulse durations and timing produce an effective operating current of much less than a steady voltage would.
                    BTW, You're making me read too much mathdog
                      Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                      The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                      The bq24745 features dynamic power management...
                      10-23-2024, 02:50 AM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                      Narrow VDC applications where the system power source is
                      either the battery pack or the regulated output of the charger.
                      This makes the max voltage to the system equal to the max
                      battery voltage instead of the max adapter voltage. Operating
                      at lower system voltage can improve...
                      11-05-2024, 04:43 PM
                      Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                      I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                      I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                      I tested the battery cells there are installed right now and they are testing good with no issues that I...
                      02-04-2025, 08:08 PM
                      Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
                      The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
                      All AP21X2SG-13 AP21X2MPG-13 devices are available...
                      10-23-2024, 03:33 AM
