APC UPS 2200XLI error 0008
  • circuito
    • Jul 2025
    • 4
    • Perú
    I got a APC UPS SRT2200XLI showing General system error 0008. It's supposed to be related to the logic power supply. I checked all I could, but because of lack of documentation I'm going blind.
    Any help will be appreciated.
    Daniel
  • CapLeaker
    Leaking Member
    • 8290
    Did you check the batteries? Is there an external battery hooked up to the unit? If so try only with the internal batteries.
    • circuito
      • Jul 2025
      • 4
      • Perú
      The main UPS PCB is on the bench. There is no external battery pack. But, I realized that when I connect the internal one, it does not get recognized but, when I unplug the mains, the Ups continue running on the battery. So there is no battery recognized, but the battery is powering the UPS. I guess there must be a voltage divider somewhere to get the battery voltage. This unit had moisture damage, some tracks were corroded, and are now fixed. One Fan is also bad and is on its way.
      Do you know if this error is related to the "missing" battery pack?
      • CapLeaker
        Leaking Member
        • 8290
        No. I don’t think it’s about the missing battery pack, as long as the internal battery is there. I think it’s the logic board. The field service manual talks about replacing it. Look around at that board and connections etc. There was a vid on YouTube at one time about a SRT2200xli error 0008 repair, but the vid itself is gone. Maybe contact that channel owner.
        • Sus256
          HISENSE 65E7KQ PRO - no boot
          by Sus256
          Hi all!
          HISENSE 65E7KQ PRO
          RSAG7.820.13512 - chassis
          MT9618BAATAB - cpu
          RSAG7.820.12059 - power
          HD650Y3U77 - panel
          KLM8G1GETF - emmc
          The TV does not turn on, the standby indicator is on. All voltages are present.
          Emms is dead. Not readable, not detected.
          Replaced emmc.
          But with another dump there is no launch
          Terminal log
          UART
          AC_ON
          RPMB key is not yet programmed
          HASH1_VERSION=0x00000000 64bit
          E-B
          FDE enabled
          layout pattern onebin by SAR7,0...
          06-01-2025, 02:11 AM
        • pkslowk
          Debug Card Error Code and Solution
          by pkslowk
          Sr. Motherboard Debug Error Code Solution
          1 Intel 845 E9 Bios Related Problem
          2 Intel 845 D4 CPU Socket Related problem
          3 Intel 845 37 Bios Related Problem
          4 Intel 845 7C Bios Related Problem
          5 Intel 945GCPE 34 Bios Related Problem
          6 Gigabyte 845 2 Ram Related Problem
          7 IBM Server A6 A7 Ram Mismatch Problem
          8 Asus 845 29 CPU Related Problem
          9 Lenovo I946 97 C-Mos Jumper related
          10 Gigabyte 845 A0 CPU Related Problem
          11 Asrock G31M-VS D7 Bios Related Problem
          12 Compaq 845 BD-70G B0 CPU Socket Related problem...
          01-28-2021, 12:51 PM
        • Superbee_dad
          Sharp 80” long short flash backlight error - Help
          by Superbee_dad
          Hello Sharp TV experts
          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
          01-24-2025, 11:51 PM
        • Curtissimo
          HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
          by Curtissimo
          Hi everyone.
          I have a HP Elitebook 850 G8.
          Serial: 5CG2324XM0
          ProdID 6L8D5EC#ABA
          It has a Winbond W25Q256JVEN Chip.
          I need to remove BIOS Password.
          I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
          Attached my dump.
          I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
          I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
          What I did:...
          08-26-2025, 04:42 AM
        • Maalobs
          Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
          by Maalobs
          I have a 2014 vintage Philips 60PFL8708S/12 that suddenly died in the middle of the kids watching a show.
          The relevant service manual for the chassis is available here.
          The TV no longer powers on, and leaving it powered on for a few minutes results in the layer-1 error with 2 blinks.
          When I short the SDM to ground I get the layer-2 error code 53.
          The inside of the TV has no damaged components and no swollen capacitors.
          In SDM-mode when all the power rails are left on despite entering the protection mode, I tracked down and measured...
          04-02-2019, 01:15 PM
