Help with acbel pch018
  • lpzrules
    • Aug 2024
    • India
    hello
    I have both the psu one is for lenovo other for hp
    my pch018 is blown but pch019 is functional and of no use to me
    actually on the psu board of both models the ps_on wire which has green black and yellow which goes into motherboard for supply is 4 pin soldered on it has 4 squares and wires soldered together
    the pch018 uses 3 slots one is empty all blacks and yellows are separate and one gree separate pch019 uses all 4 slots with mix of yello black and green
    there are 9 wires inpch018 and 10 in pch019
    the pch018 has output from the 4 pin connector a 6 pin mb and 4 pin cpu and pch 019 uses 4 pin for mb and 4 pin for cpu also it has power for sata in this but the pch018 i have to use another wire to give power to sata directly via the mb
    but connection to the board is 4 pin only soldered i dont know what that is called i was thinking of desoldering that and swapping is that possible ?
  • DoOm86
    Doubts about: working laptop without a soldered ram/vga/battery
    by DoOm86
    I'm new to elettronic, so perhaps my question has no sense.
    Can a laptop still work without one of the soldered ram?
    I was wondering if a laptop (or any other device actually) can still works if removing a faulty soldered ram without soldering back a good replacement. Of course considering the mainboard has other ram chip perfectly functional.
    I tried on a MacBook Air and also an Asus laptop and it seems no possible without a replacement. At least, not just removing the faulty one.
    Sometimes for the seek of data recovery on a flash soldered drive on the mainboard,...
    04-14-2023, 05:05 AM
  • acedogblast
    Soldered wifi upgrade to wifi 7 BE200D2W from older AX2xx based moduels.
    by acedogblast
    I have finally found a source for Intel's BE200 wifi soldered "1216" sized modules (not the larger 2230 removable M.2 modules) and I was wondering if it is possible to swap the older AX2xxD2W wifi 6/6e with this new wifi 7 module on a laptop. Supposedly both the BE200D2W and the older AX2xxD2W chips use the standard "M.2 1216 footprint" but with an additional inner-ring of pads. We have schematics of various laptops that use the AX2xxD2W chips on this forum. What we need is a schematic of a laptop that uses the new BE200D2W to check if the pinout is identical or not. Do anyone...
    11-16-2024, 10:19 PM
  • Sparklingx
    CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
    by Sparklingx
    So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
    So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
    now all...
    08-29-2024, 01:53 PM
  • Lukosiukas
    Asus GA401Q disabling soldered ram
    by Lukosiukas
    Hello, i have question about ASUS ROG GA401Q, the integrated "soldered" ram has many errors when testing with MemTest, can i disable it ? i have access to all soldering equipment, bios programmer.
    Have a nice day!...
    06-06-2024, 02:33 AM
  • asussucks
    General question regarding resistors and soldered RAM
    by asussucks
    Hello there!
    I'm curious to know what would happen if you moved the resistors to the other location while viewing a DIMM_SEL in the schematics.
    i know if you move all of them to the other location you will be effectively disabling the onboard memory.
    but im curious to know what would happen if you ONLY do it for specific ones?
    i have a bad ram chip on a laptop motherboard and id rather be able to use that laptop than paying 500 bucks for a new motherboard. and im not good with soldering ram so im not gonna attempt to fix it that way. (not that i know which...
    09-02-2025, 11:19 AM
