General question regarding resistors and soldered RAM
  • asussucks
    • Sep 2024
    • 6
    Hello there!
    I'm curious to know what would happen if you moved the resistors to the other location while viewing a DIMM_SEL in the schematics.
    i know if you move all of them to the other location you will be effectively disabling the onboard memory.
    but im curious to know what would happen if you ONLY do it for specific ones?
    i have a bad ram chip on a laptop motherboard and id rather be able to use that laptop than paying 500 bucks for a new motherboard. and im not good with soldering ram so im not gonna attempt to fix it that way. (not that i know which ram chip is bad anyways.)
    so yeah what would happen if you only switch SOME of them off?
    Thank you for your help
  • Sebastian163
    • Apr 2023
    Don’t do it, that’s not a good way to fix your issue. Try to remove the ram with hot air and flux it’s not that hard actually.
    • asussucks
      • Sep 2024
      • 6
      well actually. i have no idea which one is the broken one.
      and i dont know how to figure that out. and once its removed i cant put it back on because i dont have a stencil. and i also dont have the paste for it.
      i just wish to disable a part of the ram .. maybe BIOS change??
      • m1ch43lzm
        • Mar 2019
        • 1032
        • Peru
        That only works if the board has additional RAM slot, you disable all the onboard RAM with a BIOS mod, or in some boards, changing resistor straps, and use only the external RAM
        But if the board doesn't have a RAM slot (all RAM is soldered), can't do anything except replacing/reballing all 4 RAM chips, as trying to find the single faulty chip is very difficult
        It depends, usually those resistors also select between different RAM vendors, such as Samsung, SK Hynix, Micron, etc, it's for loading the specific RAM timings for each RAM vendor, example: SK Hynix RAM may not like Samsung timings
        Only in case you got the model with the highest RAM capacity, there may be a combination for half the RAM amount and same vendor, if the laptop was sold with that specs
        Example: you have the 16GB model, but a 8GB model was also sold, there may be a table in the schematics related to ram capacity/brand, but without the full schematics I don't know which resistors to move, and there's a chance it won't work depending which RAM addresses are faulty...
        • asussucks
          • Sep 2024
          • 6
          oh nice. yeah it was sold with an 8gb variant. same motherboard. and i am sure i can find the schematics for it too. if i found it for this one im pretty sure i can find it for the other one.
          so what you're saying is. if i switch them to be the same as the ones in the 8gb variant ill possibly be able to run it with 8gbs instead. correct?
          • m1ch43lzm
            • Mar 2019
            • 1032
            • Peru
            https://www.badcaps.net/forum/troubl...77#post1825577
            From your screenshot is this one, right?
            Take note of the positions of DIMM_SEL2, DIMM_SEL1, DIMM_SEL0, which resistors are populated, if a resistor is connected to +3VSUS equals "1", if its connected to GND equals "0"
            Example:
            For DIMM_SEL2 there are 2 resistors, R2105 and R2106; R2105 connects DIMM_SEL2 to GND and R2106 connects DIMM_SEL2 to +3VSUS, if R2105 is populated (and R2106 should be empty=, you have a "0"
            For DIMM_SEL1 R2103 goes to GND "0", and R2104 goes to +3VSUS "1"
            For DIMM_SEL0 R2101 goes to GND "0", and R2102 goes to +3VSUS "1"
            Now make a note of the initial value of DIMM_SEL2, DIMM_SEL1 and DIMM_SEL0, example: 001
            Try moving DIMM_SEL2 from R2105 to R2106, now you have 101, check if it powers on, and if it does, check the reported RAM capacity
            Click image for larger version  Name:	Captura de pantalla 2025-09-04 193850.png Views:	0 Size:	46.6 KB ID:	3718731
            The above table is taken from a different ASUS board, no guarantee it's the same for yours as the schematic diagram is not available for the X7400PC, only the boardview, there are 6 valid combinations depending on capacity and vendor
            The other option, is to find a closeup picture of the same area for the 8GB motherboard, you'll notice the position of the resistors is different
            No guarantee that it will work, proceed at your own risk
            • TinkerTron
              Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
              by TinkerTron
              Hey everyone,
              I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
              Instead, here's what's been bugging me so far:
              The schematic...
              03-06-2025, 02:03 PM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • ttmi100x
              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
              by ttmi100x
              Greetings everyone,
              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
              Upon closer inspection...
              07-31-2024, 06:36 PM
            • brightest_z
              Hot Air Blew Away Resistors Near Bios
              by brightest_z
              Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
              Does anyone with more knowledge, and experience than I, know if this is the case?
              12-11-2024, 08:34 PM
            • DoOm86
              Doubts about: working laptop without a soldered ram/vga/battery
              by DoOm86
              I'm new to elettronic, so perhaps my question has no sense.
              Can a laptop still work without one of the soldered ram?
              I was wondering if a laptop (or any other device actually) can still works if removing a faulty soldered ram without soldering back a good replacement. Of course considering the mainboard has other ram chip perfectly functional.
              I tried on a MacBook Air and also an Asus laptop and it seems no possible without a replacement. At least, not just removing the faulty one.
              Sometimes for the seek of data recovery on a flash soldered drive on the mainboard,...
              04-14-2023, 05:05 AM
