CURTIS CONTROLLER 1264-5403
  • Éric Noiseux
    • Apr 2025
    • 9
    I don't know if I'm in the right place, but I'll take a chance. I would like to know if it is possible to have the boardview for this type of controller. I have a light that shows errors on the selenoid power supply. I opened the controller, I saw nothing that would indicate anything was burning. I have no idea what values I should be looking for.
    Anything will be greatly appreciated. THANKS.​
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Curtis Instruments motor controllers are designed in their division in Livermore, California. https://www.curtisinstruments.com/pr...or-controllers
    PeteS in CA
    • Éric Noiseux
      • Apr 2025
      • 9
      "Okay, thanks a lot, I'll check it out as soon as I can. Can I really find the issue with this document?"
      • Éric Noiseux
        • Apr 2025
        • 9
        The 1268 controller looks really similar to mine, but looking at the picture I think it's a Curtis approved FSIP controller, I'll check when I get back to electronics class as I brought the controller as a repair project. I'll give you news as soon as I have some, thanks again.
        • stormanimal83
          Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
          by stormanimal83
          Hey....
          Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
          my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
          01-18-2024, 02:15 PM
        • master3112
          ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
          by master3112
          I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
          When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
          10-29-2024, 09:32 PM
        • ronnygracias
          Help with freemotion incline trainer with controller comm error
          by ronnygracias
          The treadmill was working fine, one day the belt snapped and after checking the unit I also noticed that the display is now showing the Controller comm error. So I opened it up and the treadmill had two boards. One is a power supply board and the other is the motor controller. I noticed there was a mouse nest, so I took power supply board out, cleaned it up, replaced the big capacitor and that did nothing. Then I took apart the motor controller and cleaned that up, and when I plugged it in, it started right up. I thought I fixed it. But when the belt arrived, I installed it and tried to power...
          11-04-2024, 01:32 PM
          Tankless hot water heater controller board not powering up when power is applied
          by sam_sam_sam
          I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
          I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
          However I would like to know if I could figure what happened to this controller board if possible
          Tomorrow I will take some better pictures of both side of both boards
          The...
          12-09-2022, 09:14 PM
          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
          by sam_sam_sam
          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
          I am comparing them to a brand new one that I installed
          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
          I going to let it run for several days before I remount back on the wall next to the...
          09-05-2024, 06:48 PM
