POWER SUPPLY BN44-01056A Power fluctuation ON MAIN CAPACITOR
  • bohaboha
    • Nov 2012
    • 1017
    • sweden
    As long as you take the main board off the PSU and "force" the PSU on and all the voltages are correct, it is safe to say you got a main board problem. We don't know what the TV model number is, nor we know what the TV main board does or doesn't do (symptoms why you think the main board is bad). Also the voltages you talk about, we haven't got a clue what pins they correspond to.
    Some pins for example the dim pin voltage depends on what the back lights are set to. The PSon and BLon pin should be very close or the same as STBY voltage. Dim, PSon, BLon comes from the main board and tells the PSU what to do. The only voltage originating by the PSU and sent to the main board is STBY.
    Maybe the main board has a short somewhere and dragging the voltage down. Who knows. Too hard to tell if we don't see the whole picture or don't get told the whole story.
    Maybe make a new thread in the TV section, since you got main board trouble.
    thank you CapLeaker allow me to be more specifique if 5V is STB stated on PS legend but it only supplies 4.3V to Mainboard would Mainboard not be negatively affected or would it work anyway?
    I'm talking about this PS we're dealing with here.
    then on this Power Supply Legend there is no specified Current Value of ANA_DIM and other how to know the correct value?
    • CapLeaker
      Leaking Member
      • 8339
      STBY sez 5V, but delivers 4.3V to the main board is fine. What does STBY do if the main board is disconnected? It is also enough voltage for the PSU to turn itself on (through a pull up resistor) when main board is disconnected.
      The ANA DIM pin voltage depends on what the back light brightness was set to and comes from the main board. It could be anything for example 3.2V, 4.3V or 2.8V.
      PSon and BLon voltage also comes from the main board. All it does is turn the PSU section responsible on or off. Back in the days Samsung didn't have the pull up resistor feature yet, so we were "forcing" the PSU on by taking a 1K ohm resistor and jumped STBY -> 1K resistor -> PSon, BLon and some Dim pins. There is a threshold (I'd like seeing at least 3V, and that depends on what TV brand). where too little voltage or no voltage from the main board provided to the PSU didn't turn the back lights on. To fix that quickly was to put a 1k resistor between PSon and BLon and called it a day, instead of getting a new main board.
      • bohaboha
        • Nov 2012
        • 1017
        • sweden
        thank you
        • chth96
          What capacitor should I purchase for Power Supply of obsolete game consoles?
          by chth96
          hello.
          I have Sega Saturn and 5 years ago, I recapped all of capacitor in the Power supply, Because At that time, It frequently freezed black screen after SEGA logo displayed.
          It hardly ever freezed after I finished to recap all of caps in the power supply.
          But Yesterday, It did not show any screen at all and its green power LED constantly blinked.
          To my surprise I found that all of two NXH 10v 2200uf capacitors in the secondary area of Power supply have been bulged and It measured 57 mF and 75 mF capacitance.
          It seems that quality...
          10-01-2024, 08:14 AM
        • Agent24
          Dick Smith Q-1760 linear power supply filter capacitor question
          by Agent24
          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
          It has at least one problem.
          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
          I have already ordered a replacement potentiometer, so that's not an issue.
          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
          All are CapXon...
          10-21-2025, 05:39 PM
          DVR camera recorder switching power supply capacitor failure really
          by sam_sam_sam
          These cheap non brand capacitors at it again
          Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
          Well at least I have the cameras back on line I to try the...
          01-22-2022, 06:28 PM
          by sam_sam_sam
          07-01-2024, 06:34 AM
