Re: Dell NPS-250KB caps
I don't know that it's a rule, but many if not all the smaller Delta's have a stamped out metal grill for the fan. Along these cut edges it may rust eventually, and be sharp enough to cut your finger if you were to run the finger across the cut edge, but that doesn't necessarily make the rust a problem so long as it's not scaling off in big pieces (if the PSU is that bad, I would wonder about the rest of it, if it's even good to redeploy it for another tour of duty).
I agree the Deer should be removed, I'm just not seeing what difference it will make if the fan exhaust grill has a little brown coloring to it, but if you just wanted the quick and easy solution, take a dry paper towel and rub it against the rust to get any loose off, then take some enamel model paint and just paint around the interior cut areas of the exhaust slits.
There is another option. Cut out the hole so it's even less restrictive, then decide whether you need a tubular (chrome, etc.) fan grill on it. I just don't know that this PSU is really worth so much time, you should be able to find a reasonable brand new 200W+ PSU for less than $40 USD. Your local mom-n-pop computer shop might even have some used ones lying around they'd sell for almost nothing. I like Delta PSU but if it's eyecandy/perfect looks you're after, Delta was never a winner there even when the unit was new and rust-free. It's also a little underpowered for many uses these days. Even a good quality PSU has to be seen as only capable of it's stated wattage for moderate term use, and better derated to account for longer life remaing after it is already several years old.
