To be -5v, or not to be -5v? That is the question
  • socketa
    Asbelowsoabove
    • Jun 2014
    • 662
    • samsara
    All of 'my' boards are socket A
    Some have just a 20-pin connector, and others have 20-pin connector + the 4-pin 12v CPU connector.
    Would any of them need the -5v rail?
    Would it be better for the Mobo if it was not present? - i.e. if SWIM was to remove it?
    If the 5v rail is connected, and it is not required, then it would be unnecessarily applying voltage to the mobo, perhaps prematurely wearing out the components that are connected to this rail.
    I can recall reading somewhere that this type of connector (with -5V) should not be used on newer motherboards, but i don't know if these mobos are classed as new - as the terms "new", "modern" and "old" can be quite ambiguous.
  • mariushm
    • May 2011
    • 3799
    Re: To be -5v, or not to be -5v? That is the question
    -5v was used by ISA slots (for example opamps on ISA sound cards may have used +/- 5v).
    I'm not aware of other components on a motherboard (except maybe onboard modems?) that would use -5v.
    -12v was used by serial ports .. and some motherboards still have serial ports or still have headers for the bracket with connector.
    -5v was made somewhat optional in atx psu standard v1.2 in 2002 and in v2.01 (2004) is not required at all in the standard.
    See page 3 here (v2.01):
    V2.2 is here: (yeah the url is fucked up by them)
    • japlytic
      • Oct 2005
      • 2086
      On some old floppy/HDD controllers, -5V was used by the data separators.
      Could -12V be deleted from the ATX standard, considering the fact that it was used on PCI slots but not on PCI Express slots?
      • mariushm
        • May 2011
        • 3799
        Yeah, it could be deleted/made optional, the motherboard could simply add an inverting dc-dc converter to make -12v from 12v. Nothing complicated, the current power supplies only offer 5-10w at best on -12v which is very simple to do.
        I would in fact give up on -12v AND 3.3v and go only with 5v, 12v and 20v (+/- 5%).
        Why 20v? Because it's standardized for usb 3.0 and it would also make it fairly easy to reuse laptop adapters/chargers to power up motherboards that have everything onboard (think itx, microatx with kaveri or similar processors, boards that don't go over 100w etc etc)
        No sense wasting 4 wires or whatever the amount is to move a few amps on 3.3v - this can be easily done by a dc-dc converter onboard, it's already there in some cases because system receives 5v standby and there has to be 3.3v or 1.8v produced for bios, chipset whatever while in standby.
        They could go further and make some i2c link (or some protocol that's open) between computer and power supply and just let the power supply default on 12v through all atx connector pins meant for 12v or 20v and let motherboard tell it if it supports 20v on just the pins meant for 20v or to send 20v through all 12v+20v pins or a subset of 12v pins (you may still want 3-4 12v wires for the pci express slots and usb 3.0 in case device can't handle 20v and falls back to 5v or 12v).
        • 999999999
          • Sep 2006
          • 774
          Some OEM motherboards and aftermarket (Creative Labs for one) sound cards had audio amp chips meant to direct drive speakers, also made use of the -12V rail to give 12V/0/-12V supply.
          Back to the original question, if -5V is connected to the board but not required, meaning not used, there is nothing it could damage. There is no ATX compliant motherboard which will have a problem with -5V being present on the corresponding PSU connector pin, not newer or older it makes no difference.
          • Nagy Daniel
            Lowest possible resistance on laptop motherboard rail - Guide Table request
            by Nagy Daniel
            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
            So, I generated a table with AI so I can...
            03-04-2025, 08:24 AM
          • Tomylee
            No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
            by Tomylee
            Sorry for the person who’s going to read all this !
            I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
            While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
            During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
            07-11-2025, 11:52 AM
          • Victor Moreira Silva
            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
            by Victor Moreira Silva
            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
            Well, my decice specs are the following:
            Model: Acer Nitro 5 AN517-54-55T5
            CPU: Intel Core i5-11400H
            GPU: NVIDIA GeForce GTX 1650
            Motherboard: GH51G LA-L181P Rev:1c
            The symptom:
            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
            05-26-2025, 10:49 AM
          • 5mall5nail5
            Help identifying connector for ASUS 4090 Strix RGB LED connector
            by 5mall5nail5
            Hi All -
            I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
            Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
            05-04-2025, 07:47 AM
          • lefetylorant
            Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
            by lefetylorant
            Hello Everyone,
            Long story short, I got this unit for very cheap.
            I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
            I've performed some measurements:
            - 20V rail perfectly...
            09-14-2023, 05:05 AM
