Hi to all forum members,
This psu (Tiny Tech model ATX 480W) had been installed in a very old Windows XP PC but recently i pulled it out as the pc cannot start. To test it, i jumped the green wire and black wire on the 24 pin connector. The psu fan jerk a bit but not spinning. I used my dmm to check dc voltage on output connector wire, the 5v red wire keeps ticking a bit at around dc1v....then drops and ticking again around 1v. It is the same situation with the 12v yellow wire.
Fyi, i desoldered the secondary side electrolytic cap those over 1000uf type, found 2 caps out of spec and replaced with new ones. Btw, i also replaced those small cap next to 5vsb diode and caps above the +5vsb purple line . The small cap next to green ps on wire tested good.
Tested the 5vsb n channel mosfet CM2N60 at primary heat sink off circuit. On diode mode, red dmm probe to source, black probe to drain. Dmm reads OL. Then black probe to gate, then to drain. Dmm reads continuity.
Voltage test on D9(standby diode) shows dc5.43v while the aux rail is dc 14.28v
In addition, i also desoldered all the resistors around the +5vsb purple wire, the 20pin pwm SD6109, nearby green ps on wire and near grey pg wire. The resistors all tested good within spec.
All the diodes also tested good within spec.
Tested voltage reading on pwm SD6109, pin 20 vcc reads dc5v. Is this sufficient to turn on the psu since the schematic of SD6109 says maximum voltage on pin 20 is dc12v.
On visual inspection, there is nothing burn or any dark spots on the pcb board and i had done most of the preliminary testing. But i might have overlook something else and i look forward to your kind suggestions and advice on how to revive and get this psu to work again. Any comments and tips on this will be greatly appreciated.
