iMac 24 PSU LITEON PA-3241-02A1 250W
  • C0C45
    • Jun 2017
    • 7
    • Portugal
    #121
    Re: iMac 24 PSU LITEON PA-3241-02A1 250W
    Thanks mate,
    I will buy TO-220, with TO-220 mica, I think that it's sufficient.
    Thanks again
    • Toasty
      • Jul 2007
      • 4171
      #122
      With the ones you showed from ebay, plastic package, no insulator is necessary.
      BTW: Be careful there. That is only for 1 piece, not 2 as pictured. I hate when they do that. Tricky bastards!
      This is a better deal: http://www.ebay.com/itm/281410772068
      T
      veritas odium parit
      • C0C45
        • Jun 2017
        • 7
        • Portugal
        #123
        Thanks mate
        • Paul Hawk
          • Sep 2017
          Hi Toasty
          I have been reading through the thread and gaining knowledge on this psu. I think I'm going to replace all the caps. its an imac 24 with the Liteon psu. About three years ago it shut down and began tripping the circuit breaker in the house. I pulled the psu and connected it to the mains power only and tripped the breaker. Last month i tested the transistors and diodes, found them all good. So i ordered a working one on ebay, but tried the psu once more and after all this time, it was working again which was really great, and i canceled my order . it has been working for about a month with light use. Well, last night I got a screen telling me i need to restart, i'm thinking its about to go out of order soon. Would you advise on this?
          • Toasty
            • Jul 2007
            • 4171
            #125
            Welcome!
            Your statement about tripping the house breaker makes me suspicious that there's something wrong with that circuit. The supply would blow its internal fuse long before the house breaker would trip.
            Recapping is a good idea. I would leave out the Mains caps and just stick to the others.
            Just make sure you don't have a motherboard caps problem.
            T
            veritas odium parit
            • Paul Hawk
              • Sep 2017
              Thank you very much I found these capacitors in post 81 in this thread. Should I only replace these?
              3 - 2200/16 - UCC KY
              1 - 2200/16 - UCC KZH
              2 - 470/50 - MAT FM
              What should I do to investigate the circuit where the fuse don't blow?
              • Toasty
                • Jul 2007
                • 4171
                #127
                I'm talking about a problem with your house electrical circuit, not the power supply.
                Yes, those are my general suggestions for caps for this PSU.
                T
                veritas odium parit
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5065
                  • New Zealand
                  #128
                  Bad inrush NTC could make the breaker trip? Or would that blow the PSU fuse?
                  -David VanHorn
                  • Toasty
                    • Jul 2007
                    • 4171
                    #129
                    There is no inrush NTC on these, but there is an MOV. It's after the fuse (5A) which would certainly blow before the house circuit breaker (15A ?).
                    T
                    veritas odium parit
                    • Paul Hawk
                      • Sep 2017
                      Yeah house is 20A and actually part of that circuit failed completely. The breaker tested good, but a several wall outlets have no power since.
                      After that I tried another outlet. Seems like the breaker tripped there also, but this is going on three years ago, the PSU was most definate dead.
                      Toasty, I found the UCC caps, but I'm not finding any MATs. Would you point me to them?
                      • Toasty
                        • Jul 2007
                        • 4171
                        #131
                        MAT = Matsushita(formerly) = Panasonic
                        I use the FM series - EEUFM1H471
                        Another choice would be the FR series - EEUFR1H471
                        Both are 12.5 x 22mm
                        Whichever is least expensive.
                        Who are you sourcing the parts from?
                        Please post the manufacturer's numbers you are ordering for review before ordering.
                        All should be 12.5mm diameter and 20 to 25mm in height.
                        T
                        veritas odium parit
                        • Lex-
                          • May 2011
                          • 18
                          #132
                          Originally posted by rwing
                          Thank you for the Pin out Sir. Yes the startup section of this psu is burnt. The pin out information you have provided me has now given me the opportunity to test my Logic board and prove that the board is still functional. I have modified an enterprise class power supply to power this logic board. I am typing from this mac logic board retrofit into an ATX Rack Mount Case running Debian 8.0 This system will now take another life with a different function.
                          P.S. any one need an Early 2009 Imac 24in Screen and Glass front cover. 75bucks for Toasty, 100 bucks for any one else.
                          Old I know but maybe rwing or someone can help, I want to do the same, I have a 2008 iMac 24 inch with dead power supply, can you explain how I can power the motherboard with a different power supply and the model/characteristics of the enterprise power supply you used ?
                          Let me know.
                          Thank you.
                          • Toasty
                            • Jul 2007
                            • 4171
                            #133
                            Why not just fix the one you have? One of the easier ones as no caps are buried under a heatsink.
                            T
                            veritas odium parit
                            • twingolover
                              • Oct 2017
                              • 6
                              • Italy
                              #134
                              i have a PA-3241-02a1 liteon power supply from a Imac opened by another tecnician.
                              i see first led green with AC, and when i press power button 2 led become green for a while then turn off....fan move a bit and see a very little smoke from power.
                              I'm not particulary expert what i can check ?
                              1 time power on with all fan moving but no video and no Apple chime sound so i think post doesn't work.
                              • Toasty
                                • Jul 2007
                                • 4171
                                #135
                                Being inexperienced, I would replace the power supply. Because of the smoke you saw, don't even bother attempting to fix it.
                                The other technician apparently screwed something up.
                                T
                                veritas odium parit
                                • twingolover
                                  • Oct 2017
                                  • 6
                                  • Italy
                                  #136
                                  i have replaced power supply with a new one.
                                  try to power up and nothing again.....just 1 green led, 2 led power on for a while , 3 and 4 off.
                                  Can be an issue on logical board?what i have to check on it? some fuse , or other components?
                                  initially this imac has an issue on graphic card (some artefacts when too hot for dust , bad thermoconduttive on cpu, never power down) .
                                  No power can be dued i'm trying to turn on without frontal cover?
                                  Please help.
                                  Thanks in advance
                                  Bye
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    #137
                                    If the cover is on or off will make no difference. It will work.
                                    What is the Apple model number of the iMac?
                                    Here: https://everymac.com/ultimate-mac-lookup/
                                    Can you provide some clear photos from different angles of the logic board and the whole unit from the back?
                                    T
                                    veritas odium parit
                                    • twingolover
                                      • Oct 2017
                                      • 6
                                      • Italy
                                      #138
                                      T
                                      Thanks for helping me....
                                      here are photos
                                      https://ibb.co/fia87b
                                      https://ibb.co/dohc0w
                                      https://ibb.co/f1BsYG
                                      https://ibb.co/cEWsYG
                                      https://ibb.co/fetvnb
                                      https://ibb.co/hop1Sb
                                      https://ibb.co/nzmRtG
                                      may help reflowing components?
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        #139
                                        You said: "initially this imac has an issue on graphic card "
                                        Was the graphic card replaced?
                                        You might have to do that. Especially if it overheated.
                                        These problems started with the graphics card, yes?
                                        T
                                        veritas odium parit
                                        • twingolover
                                          • Oct 2017
                                          • 6
                                          • Italy
                                          #140
                                          T
                                          initially imac have issue with artefacts.
                                          No GPU wasn't replaced
                                          Power make smoke on startup.....so i try to replace it assuming was a power issue.
                                          so only 1 led can be the issue on GPU?
                                          • mat2k
                                            iMac 2017 PSU - shorted PFC mosfet
                                            by mat2k
                                            I am trying to fix an iMac 2017 PSU, initially came with a blown fuse and shorted PFC MOSFET (6R199P). After visual inspection and some measurements I replaced the FET with a P20NM60 and tested with 100w series lamp, and it lasted 1 second before going into dead short. The PFC controller chip (NCP1605BG) and its passives appear fine (passives measure OK), but I do not know if there is a simple way of testing the NCP1605 as I wouldn't like to blind-replace it.
                                            There was some slight blackening of the solder on the PFC controller passives so I reflowed them all with some flux. I am waiting...
                                            03-13-2025, 11:31 AM
                                          • Jane
                                            How do you test MOSFET in laptops ?
                                            by Jane
                                            I tried to use this method:
                                            Testing an N-channel MOSFET:
                                            Step 1: Discharge the Gate (turn off the MOSFET)
                                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                            Step 2: Charge the Gate (turn on the MOSFET)
                                            Now, place the red probe on the Gate (G) and the black probe on the
                                            09-27-2024, 03:31 AM
                                          • MikeCebula
                                            Apple 24" iMac A1225 Liteon PA-3241-02A1 schematic and boardview
                                            by MikeCebula
                                            Request schematic and possibly boardview for Apple 24" iMac A1225 Liteon PA-3241-02A1
                                            Thank you,
                                            Mike
                                            11-04-2023, 10:18 PM
                                          • Nooy
                                            VGA MOSfet permanently shorted and loss of MOSfet pad
                                            by Nooy
                                            Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                            I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                            02-14-2024, 02:26 AM
                                          • redbaron1007
                                            Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                                            by redbaron1007
                                            I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                                            Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                                            09-09-2025, 11:10 AM
