iMac 24 PSU LITEON PA-3241-02A1 250W
  • Toasty
    • Jul 2007
    • 4171
    #101
    Re: iMac 24 PSU LITEON PA-3241-02A1 250W
    That's all the voltages you will get from the CN1 connector.
    Your 24v line is on the single inline 12 pin connector CN2 on the opposite edge of the board. Pin 1 is at the corner next to the mounting hole. The 5 pins 8-12 provide the 24v.
    If you have these with a lamp load on them and voltages check, then the supply is good.
    I suspect your problem lies on the mainboard/motherboard.
    T
    veritas odium parit
    • LuisJCC
      • Feb 2017
      • 15
      • Spain
      #102
      Originally posted by Toasty
      Excellent! Yes, that's what I would have done next. It's the only place a short could be between those pins. That's why I drew the trace lines on the picture and sent the IC electrical PDF. Once you examine the circuits they show, it was the only logical explanation.
      You figured it out, and that's great!
      I hope you can acquire a new one. If you need help finding one, use this link to the Find Chips website - findchips.com .
      Good Job!
      T
      fuse dead one more time...
      Trying to find new shorts...
      • Toasty
        • Jul 2007
        • 4171
        #103
        You replaced the IC that fast? Where did you get it that fast?
        With a lamp in series? The lamp may glow brightly, but nothing should blow...
        Since you didn't answer before (Post 78), what is the condition of the fuse? Blackened or just open?
        Did you check for the short (again) between gate-drain?
        T
        veritas odium parit
        • LuisJCC
          • Feb 2017
          • 15
          • Spain
          #104
          Mr. Toasty, what do you think about "bridge" the fuse?... I think it´s bad but... I don´t have another idea to do...
          • Toasty
            • Jul 2007
            • 4171
            #105
            That's called Dancing with the Devil. You ONLY do that if you use the lamp in series.
            You SHOULD be doing this work with an Isolation Transformer.
            T
            veritas odium parit
            • LuisJCC
              • Feb 2017
              • 15
              • Spain
              #106
              T
              First I try with the 220v lamp in series but the lamp doesn´t light on (plug the wire to electricity) and I don´t have any volts in the enter of the board... I decided extract the lamp and connect directly to the PS. The fuse dead one more time.
              The fuse is only dead, not blackened, only just open. It´s different but 5A/ 250v
              • LuisJCC
                • Feb 2017
                • 15
                • Spain
                #107
                T
                What does it means? --> You SHOULD be doing this work with an Isolation Transformer.
                • techman1025
                  • Jun 2014
                  • 497
                  Hi
                  Next time just test the fets easy diode mode pull the date sheet to see where the drain source and gate legs are reversing your probes a reading from 100 to 400 or more one way reversing probes a zero in other direction is a good working fet. Caps by a good ESR METER ... is some cases it good to pull the fet and check the solder landing pads for short again diode mode on meter red probe on a ground pad black probe on landing only one leg should be grounded.
                  Techman1025
                  • LuisJCC
                    • Feb 2017
                    • 15
                    • Spain
                    #109
                    Mr Toasty, watch the video please do you think is it working ok?
                    https://youtu.be/AWoBHj8qMH0
                    • Toasty
                      • Jul 2007
                      • 4171
                      #110
                      You must use an INCANDESCENT light. CFL, LED, flourescent are not proper.
                      Looks like it's working though.
                      T
                      veritas odium parit
                      • C0C45
                        • Jun 2017
                        • 7
                        • Portugal
                        #111
                        Hi, anyone can tell me the name this mosfet please ?
                        Thx
                        • Toasty
                          • Jul 2007
                          • 4171
                          #112
                          Bob
                          veritas odium parit
                          • C0C45
                            • Jun 2017
                            • 7
                            • Portugal
                            #113
                            You were very helpful, now i can buy a new bob
                            • Toasty
                              • Jul 2007
                              • 4171
                              #114
                              Marked: 6R165P
                              Manufacturer (Infineon) Part Number: IPW60R165CP
                              See attached datasheet.
                              The original is in a plastic TO-220 package. Appears you can only get those from China. (ebay)
                              The US suppliers (Arrow, Digi-Key, Newark, Mouser, etc.) have them in the TO-247-3 package per the datasheet. You will need a longer screw to handle that package as a replacement.
                              Why are you looking for the part? General interest or is it defective? A bad one of those would be odd.
                              T
                              veritas odium parit
                              • C0C45
                                • Jun 2017
                                • 7
                                • Portugal
                                #115
                                thanks
                                This is a imac that come from a PC technical assistance without this mosfet, and they said that this PC had no repair.
                                I searched for PSU datasheet without luck.
                                I will buy these mosfet to try understand the real problem.
                                Thanks again
                                • Toasty
                                  • Jul 2007
                                  • 4171
                                  #116
                                  Okay!
                                  It is odd for that MOSFET to fail.
                                  Once you replace it, please make sure you use the incandescent lamp in series as I referenced in Post 88 of this thread.
                                  Please be very careful as you are dealing with the Mains power on this MOSFET and surrounding circuit.
                                  T
                                  veritas odium parit
                                  • C0C45
                                    • Jun 2017
                                    • 7
                                    • Portugal
                                    #117
                                    thanks mate,
                                    but the mosfet you tell me is wrong, its too big. You have the PSU datasheet ?
                                    • Toasty
                                      • Jul 2007
                                      • 4171
                                      #118
                                      Yeah, my mistake.
                                      The TO-247-3 is the wrong package for this PSU. * Identical electrically.
                                      So, you are restricted to the TO-220 package(s).
                                      In original (plastic) or in earlier versions (metal tab). * Metal tab will need an insulator for the screw and a heatsink mica or silicone insulator.
                                      Looks like you're stuck going to ebay and China for these.
                                      T
                                      veritas odium parit
                                      • C0C45
                                        • Jun 2017
                                        • 7
                                        • Portugal
                                        #119
                                        This ?
                                        http://www.ebay.com/itm/6R165P-Infin...-/251340598076
                                        • Toasty
                                          • Jul 2007
                                          • 4171
                                          #120
                                          Yup!
                                          T
                                          veritas odium parit
                                          • mat2k
                                            iMac 2017 PSU - shorted PFC mosfet
                                            by mat2k
                                            I am trying to fix an iMac 2017 PSU, initially came with a blown fuse and shorted PFC MOSFET (6R199P). After visual inspection and some measurements I replaced the FET with a P20NM60 and tested with 100w series lamp, and it lasted 1 second before going into dead short. The PFC controller chip (NCP1605BG) and its passives appear fine (passives measure OK), but I do not know if there is a simple way of testing the NCP1605 as I wouldn't like to blind-replace it.
                                            There was some slight blackening of the solder on the PFC controller passives so I reflowed them all with some flux. I am waiting...
                                            03-13-2025, 11:31 AM
                                          • Jane
                                            How do you test MOSFET in laptops ?
                                            by Jane
                                            I tried to use this method:
                                            Testing an N-channel MOSFET:
                                            Step 1: Discharge the Gate (turn off the MOSFET)
                                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                            Step 2: Charge the Gate (turn on the MOSFET)
                                            Now, place the red probe on the Gate (G) and the black probe on the
                                            09-27-2024, 03:31 AM
                                          • MikeCebula
                                            Apple 24" iMac A1225 Liteon PA-3241-02A1 schematic and boardview
                                            by MikeCebula
                                            Request schematic and possibly boardview for Apple 24" iMac A1225 Liteon PA-3241-02A1
                                            Thank you,
                                            Mike
                                            11-04-2023, 10:18 PM
                                          • Nooy
                                            VGA MOSfet permanently shorted and loss of MOSfet pad
                                            by Nooy
                                            Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                            I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                            02-14-2024, 02:26 AM
                                          • Tomylee
                                            HP 15-fc0007ca Charger Cycling On/Off with Hot MOSFET – Need Component Info
                                            by Tomylee
                                            I have an HP 15-fc0007ca that works normally, but when I plug in the charger while the laptop is powered on, the charging cycles on and off repeatedly—it starts charging, stops, then starts again.
                                            Using a thermal camera, I identified a MOSFET that is overheating, along with a small 2R2 resistor next to it that gets even hotter than the MOSFET.
                                            I also hear a “zpzpzpzp” type noise, but the noise is not coming from the same area as the hot MOSFET. I will include a photo with the exact spot where the noise is coming from highlighted.
                                            11-26-2025, 12:24 PM
