Need Help with a Yamaha DXR10 Smoking SMPS
  • Briesmith
    • Apr 2022
    • 15
    • United Kingdom
    I am trying to repair a Yamaha DXR10 powered amplifier but finding it difficult because I have a smoking resistor which starts to burn as soon as I switch power on. (So I have it turn it off straight away.) The fuses don't blow and I connect a dim bulb which goes dim so no straight short to find. I have attached a marked up circuit diagram and I am looking for help in identifying the best place to look for what's causing the excessive power draw. Needless to say the amp isn't working. The mosfet circled in red was the start of my problem when it exploded. I replaced it and the resistor network also circled in red. The circuit in question and the components I am suspicious of are circled in yellow and numbered in blue.
    No 1 marks the resistor that smokes.
    No 2 marks a mosfet that seems to test OK.
    No 3 marks a resistor that tests OK.
    No 4 shows where the circuit joins the PWM.
    No 5 ids the last capacitor in the circuit before it goes to ground.
    No 6 shows where the mains AC seems to provide a GND for the circuit. (Don't understand why the mains AC joins the rectified AC coming from the bridge rectifier at No 8.)
    No 7 circles a structure I just don't understand.
    If anybody can advise where I should start to look for the source of excess current I will be grateful.
    Best wishes
    Brian
    Click image for larger version  Name:	DXR Problem Mark up.png Views:	0 Size:	509.3 KB ID:	3530647
    • 31051
    check c108 and d101 on the far left, and c118 - the big cap on the right.
    it's typical japanese design - overcomplex to use less chips and keep the resistor and transistor companies afloat!
    i cant really tell what the hell it's doing!
      • 31051
      looking at it more, the circuit feeds back on itself so much you may find it quicker to check none of the small transistors are shorted than to try to understand what it tries to do!
      • Briesmith
        • Apr 2022
        • 15
        • United Kingdom
        Thank you Great Sage for taking the trouble to look at my problem. There are several structures, clusters of components, that I have no idea what their purpose is. And I've never encountered a design where the rectified output from from the Bridge rectifier is joined to the unrectified mains in as in this case. But thanks again for trying to get your head round things for me, much appreciated.
          • 31051
          another aproach may be to get a datasheet for the pwm chip and start looking at the signals on it to see if any are missing.
          • redwire
            • 3910
            Mosfet Q102 and the smoking resistor R116 are the start-up power for the primary PWM section.
            Normally, if mains voltage is enough and C108 charges up there is enough gate voltage to turn on Q102 which supplies power to the PWM control IC 12VDC rail (4).
            The SMPS is then supposed to start and run. Then power is from IC102 the 12V reg. from the aux. winding. Which also causes start-up mosfet Q102 to get switched off by the aux. winding also turning on Q101, once the SMPS is running.
            I would guess the SMPS is not running and it ends up spending too much time in start-up mode and the resistor runs hot and smokes, as it should. It's only supposed to be on Q102/R116 for a few seconds.
            So I would check the SMPS for faults. Power mosfets Q106, Q107 and the sense resistors etc. The array of six resistors R148-R151, R211, R212 is just to save money instead of using one resistor there. They might have fused open-circuit?
            I have heard of some people lifting a leg on the smoking startup resistor to disconnect it, and then powering the SMPS IC from a couple 9V batteries (for 18V) at point say TL107 and seeing what the PWM controller is doing. But this is hard, a last resort, powering it from mains and poking around with a scope etc. No fun.
            Weird the UCC2893 datasheet show the IC has a start-up power circuit built in at pin 16. So that is supposed to power the IC as well. I would say it's not enough to power that nutbar eco-green pulse transformer snubber thing, so Yamaha added all that shit.
            Yamaha does have bizarre electronics designs that end up no cheaper than if they did it in a straightforward manner.
              • 31051
              actually the line of resistors is not to save money,
              it's to increase the length from end to end to minimise the chances of it arcing over if anything goes wrong.
              it's a standard thing in high voltage circuits to increase the gap a spark would have to jump across.
              • Briesmith
                • Apr 2022
                • 15
                • United Kingdom
                Grateful thanks to you both. The main buggeration is there's no time to test or measure anything before I have to switch the amp off to stop the resistor bursting into flames. At the moment I am removing items of interest and testing them on the bench to see if they are OK or not. But that's very destructive and a risky approach as it can introduce errors and faults that weren't there previously. Fault finding on equipment you can't turn on is very difficult!
                • redwire
                  • 3910
                  I was talking about the array of six sense-resistors to make up a 39.6mohm 6W which ends up well over 18A really so Yamaha must only populate one or two of them. They are all so small ~0.051-0.068 ohms 1W each they must leave some out.
                  To power this thing for a long time, I'd disconnect the smoking resistor and use a 12V battery (that can be hazardous live it will be "hot") to power the PWM controller IC. It's dangerous to poke around a live primary section either way.
                  • R_J
                    • 9551
                    If Q107 shorted, causing the source resistors to go open, The UCC2893 is very likely bad, When the source resistors went open, and Q107 was shorted, around 380vdc was sent to the CS pin of the ic, if the mosfet was shorted drain to gate it likely damaged the ic's gate drive as well
                    • Briesmith
                      • Apr 2022
                      • 15
                      • United Kingdom
                      Thanks again everyone. RJ don't you know it's Christmas? Supposed to be a time of goodwill! (I'm secretly dreading the rational conclusion that I will have to replace the PWM IC if only to eliminate it as failing but I don't want to do that until I'm sure there's not still a circuit problem that will just blow it up again.)
                      • mikey5791
                        Need help to replace burned resistor in 350w atx psu
                        by mikey5791
                        Hi to all forum members,
                        Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                        The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                        Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                        Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                        12-26-2024, 04:55 AM
                      • MidnightRoller
                        Can a resistor lose resistance after hot air?
                        by MidnightRoller
                        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                        02-02-2022, 11:46 PM
                      • artvandalai
                        What resistor ohm will work better to repair this waterpik?
                        by artvandalai
                        The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                        01-05-2025, 04:10 PM
                      • Astonished
                        Fixing the Charge Circuit of the Batteries of the DC Motor
                        by Astonished
                        Hi friends of electronics
                        What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                        The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                        Please help me fix this circuit.
                        (the datasheet of the IC: https://pdf.datasheet.live/28...
                        01-28-2025, 06:24 AM
                      • chth96
                        Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                        by chth96
                        I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                        Since then, This AC/DC adaptor have been out of order.
                        But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                        After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                        And Is there any possibility that it will suddenly explode as well as to be out...
                        12-03-2023, 04:40 AM
