Ultrastudio 4k 2 Power problem
  • NConstantinou
    • May 2017
    • 348
    • Cyprus
    i have the above device which consist of power supply and control board.
    the power supply has output 12vdc which is connect to main board.as it is connected i get only 2.2vdc. when is unplugged i get 12vdc. is that correct. i do not have thunderbolt to test the device.
    thanks
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8321
    Can be 2 problems:
    A: The capacitors in the power supply are bad and can't handle the load
    B: there is something bad inside the mixer and drawing a lot more current than it should.
    Always go for the low hanging fruit first. Check, repair or replace the power supply first.
    • R_J
      • Jun 2012
      • 9588
      Try connecting the power supply 12v output to an automotive lamp like a 1157 or similar and see if it lights and check the voltage across it.
      • NConstantinou
        • May 2017
        • 348
        • Cyprus
        thank you for your reply
        i connected i 12v dc motor and i do get 12.6v across it. that means power supply is ok.
        when i connect the 12v dc power supply to the connector (power supply+ control board) i do get short but mo matter what voltage i select the amperage does not pass 1.25-1.3a and components do not get hot to see what is defective.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8321
          Upload some high resolution, straight shot pictures using the attachment function, so we can see something.
          • NConstantinou
            • May 2017
            • 348
            • Cyprus
            thanks for your reply.
            i am attaching the images
            • NConstantinou
              • May 2017
              • 348
              • Cyprus
              i managed to repaired it. there were 2 50mf 50v capacitor on main board and one of them was bad. i changed both.
              i found that when i noticed that the feedback voltage on optocoupler was very low.
              thanks for the help
