HP Proliant PSU
  • clearchris
    • Dec 2013
    • 687
    HP Proliant PSU
    Ok, been having a server reboot intermittently. I suspect the psu. I removed the psu, and have it running on a seperate psu.
    Input is 120v (240v optional) output is 12v, -12v and 5v.
    I'm considering a partial recap, though I'm concerned about how tight the space is.
    Any advice for a psu noob?
    Pics to follow.
    • 31051
    Re: HP Proliant PSU
    foto's
    inc the mother board would be good.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Re: HP Proliant PSU
      If it's a mission critical system please order a new, genuine power supply - if it's not mission critical, pop it open and check the caps. Post pictures if possible.
      • c_hegge
        • Sep 2009
        • 5219
        Re: HP Proliant PSU
        If it's got bad caps, I disagree. If it's mission-critical, Recap it. A new genuine replacement will come with the same caps and suffer the same fate in a few years.
        • clearchris
          • Dec 2013
          • 687
          Re: HP Proliant PSU
          I finally got to a computer to upload this.
          Its not mission critical, and I have spares. Spares that I expect to fail in a similiar way. The office in which they are kept runs hot, and has a tendency to kill caps. Long term I need to provide for better ventilation.
          In the meantime, I consider repair. Difficulty here is the PSU is tight on space. Tight like I havent seen before.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Re: HP Proliant PSU
            That's a great looking PSU with good caps, at least the ones I can see.
            If this is a capacitor issue, it might likely be one or more of the little ones on that daughter board. Otherwise, check for cracked solder joints too.
            Muh-soggy-knee
            • clearchris
              • Dec 2013
              • 687
              Re: HP Proliant PSU
              None of the caps appear bad under visual inspection. no bulges, no leaks. I just checked, new psu has been up for 2 days with no issues. History points to capacitors as its an intermIttent issue and, well I have had to replace the caps in almost everything else in the rack.
              I'll check for solder joints and take a better look at the small caps tomorrow, thanks!
              Overall, I really like these hp proliant servers. Its an old one, but its built like a tank. Only downside is they run hot and loud.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4960
                • New Zealand
                Re: HP Proliant PSU
                That little green one right next to the heatsink on the main board in the first picture looks suspect to me. Maybe it's just the angle or the dust, but it doesn't look flat on top.
                Check there aren't any shitcaps hiding in there. In an ML310 Proliant's Delta PSU I found a bloated and dead CapXon on the 12v rail. A CapXon, in a 'server-grade' PSU. FFS!
                -David VanHorn
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  Re: HP Proliant PSU
                  I noticed that too and was wondering the same thing. If it's a Taicon, change it. If it's a Samxon GF, definitely change it.
                  Caps don't have to look bad to be bad. My most recent example was just yesterday. I had a wireless router go down. Reason: bad Hermei caps that looked "just fine". What's even more maddening is that I could have saved this router if I trusted my instinct and changed those caps. Now it's dead with the RAM and/or main chip shorted. The router uses a buck DC-DC step-down regulator, and when the input cap went bad, its output went as high as 5.5V (it should have been 3.3V!) I think the wireless chip went bad too, because it shows about 2 Ohms between its Vcc and ground.
                  The router was making a horrible hissing noises and I thought it might be bad caps. I de-powered it and powered it on again, and that's all she wrote. If I trusted my instinct and changed those caps "blindly", I would have saved it.
                  So all I'm trying to say with this: don't ignore caps just because they look good - especially when they are from a crap brand.
                  Now, I don't consider Taicon all too bad, but if in doubt, change them. As for Samxon GF, change them regardless.
                  • Neuromodulator
                    • Aug 2016
                    • 4
                    • Chile
                    Re: HP Proliant PSU
                    Were you able to repair it? I got 3 of these that are not working at all. I got the schematics as well (took me a lot of work to get them). But still can't figure out whats wrong. Apparently the PFC subsystem isn't working as it should since its not outputting 380V.
                      • 31051
                      Re: HP Proliant PSU
                      pfc may need the 5v standby to drive it.
                      can you upload the schems?
                      • Neuromodulator
                        • Aug 2016
                        • 4
                        • Chile
                        Re: HP Proliant PSU
                        Dunno if its possible to upload to the server, but i uploaded it to some random site:
                        http://www.filedropper.com/ps-3381-1c2
                        the 380V line is actually at 317V (pretty much the peak voltage of mains).
                        Which looks as if the boost converter is not switching at all.
                          • 31051
                          Re: HP Proliant PSU
                          nice
                          ok do you have 5v standby?
                          if not then 3rd schematic has it - it's using a topswitch.
                          those things have a small startup cap.
                          usually 10-22uf - that probably is gone even if it's not the cause.
                          • Neuromodulator
                            • Aug 2016
                            • 4
                            • Chile
                            Re: HP Proliant PSU
                            You mean the C600 10uF? I'm gonna check it.
                              HP ProLiant xw460c ProLiant 5120 Specification for Upgrade or Repair
                              This specification for the HP ProLiant xw460c can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProLiant xw460c boardview and ProLiant xw460c schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                              09-12-2024, 02:15 PM
                              HP ProLiant xw460c ProLiant X5260 Specification for Upgrade or Repair
                            • Ahari
                              by Ahari
                              I...
                              08-13-2025, 06:12 AM
                            • mixmax
                              Samsung A53 5G SM-A536F switching off intermittently
                              by mixmax
                              Samsung A53 5G SM-A536F dropped, screen cracked. replaced. Phone works now, but switching off intermittently. It doesn't turn on at all if phone is assembled and all screws are in. When motherboard is loose, it works. I suspect, there is a crack in the MB or pin on some component. The question is:
                              is repair attempt feasible and what is the best way to do it?
                              01-31-2025, 05:07 AM
