Your spare PSU Stash
Re: Your spare PSU Stash
I admit,I would use a modded Deer PSU.
Or high-end Allieds modded with good schottkys and 13009s or better.
Seriously,Allied seems to be the high end line of Deer(or at least was until 2012),being on par with older Macrons,while L&C is the bottom of the barrel line and original Deers (2000/2001 ones and DR-A300ATX with 2003 chip) in the middle line.Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
Yeah I would use a modded one too. Just make sure to run it within it's proper ratings (200-250W max output?).I admit,I would use a modded Deer PSU.
Seriously,Allied seems to be the high end line of Deer(or at least was until 2012),being on par with older Macrons,while L&C is the bottom of the barrel line and original Deers (2000/2001 ones and DR-A300ATX with 2003 chip) in the middle line.Muh-soggy-kneeComment
Here is the ultra modded Allied psu you are looking for:
https://www.badcaps.net/forum/showthread.php?t=37542
Oh yes,the 8460BTX. I have a Premier built like that (except it uses the 4 diodes and doesn't have the fan PCB) that I want to get up and running. Seems mine is made from weaker PCB material,as I had to redo some connections under the PCB since some traces broke away when I removed the secondary heatsink. I've seen this kind of fix even on PS1 PSUs where the board had a crack near the power switch.Here is the ultra modded Allied psu you are looking for:
Also worth mentioning is TELVM's recapped Tuallin LC-B350ATX,which seems to be the same as an Allied AL-A300ATX (I've seen one here). 2003 chip as opposed to yours which has the 2005Z chip.
If I can get my JNC LC-B300ATX to work (untested to see if it goes
when plugged in) I'll make sure to beef it up,since it's the same platform TELVM worked with - Y-B200ATX v2.6/X-B2002ATX v2.3
Here's a list of what I plan to do in case it works:
Code:-add PI coils on the secondary -add common choke on the primary (need to check the orientation of the coil on the board) -replace diode bracket with SBL2040CT - I don't have any 60v-100v VRRM schottky,only 40 and 45v,but I've heard reports of PSUs working fine with 45v VRRM 12v schottkies -SBL3040PT for 5v - plenty,since I plan using it with an ASUS A7V8X board) -probably another SBL3040PT for 3.3v -better fan - currently has an "Colorful" brand fan
Main rig:
Gigabyte B75M-D3H
16GB DDR3-1600
Delux MG760 case
It is easy to work on those platforms. Yes, I have experienced too some traces lifting but this can be fixed quite easily.
Yesterday I picked a PC case from the street. Inside there were just 2 psus with their fans removed. 1 is a DELTA that I am planning to recap/repair and the other is 8460BTX similar with the one that I modded but more gutless. I will post photos soon!Comment
Posted some photos of the Allied psu on the gutless, bloated and fried power supply thread!Comment
Just saw it.
And I was the one that thought 2005Z based Deers were almost indestructible. What did fail in that PSU?
As for the T&P-Meiji,take the wires. I see they're 16 or 18AWG.Main rig:
Gigabyte B75M-D3H
16GB DDR3-1600
Delux MG760 case
Maybe the 5vsb critical cap went bad and the voltage skyrocketed. Can't say for sure though.Comment
This specification for the HP EliteBook 850 G5 + Mini Dock, Bag & Spare AC Adaptor Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Mini Dock, Bag & Spare AC Adaptor boardview and 850 G5 + Mini Dock, Bag & Spare AC Adaptor schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-06-2024, 08:50 AM
by objecttothisI had a desktop form factor mini-server die on me a few weeks ago. Through my initial diagnostics, I was convinced it was the motherboard because when I shorted the Green wire on the ATX connecter, the multimeter gave me all the correct voltages on the various pins of the ATX connector and 5VSTB was also correct. To my surprise the replacement motherboard wouldn't turn on with the case power button either. I threw in another PSU and it turned on right away. This is an 80 Plus EVGA 430W PSU with PN:100-W1-0430. I pulled the cover off and don't see any immediately obvious blown caps or scorch...
It's been a while since I've run into this before, so I could use a little help. The attached image is a close-up of a solid white screen. What I'm seeing is red-green-blue-black-red-green-blue instead of red-green-bue-red-green-blue.
I haven't cracked into the thing yet, but before I do, has anyone encountered anything like this before? If so, what was the solution? T-Con? Ribbon connections? Something else?1 Photo -
by TopcatIt's been a LOOOONG time since I've done one of these.... I've had the case for years, its just been sitting in my office with crap stacked on top of it. It has a Micronics 486 motherboard in it with a DX4-100 CPU.... I was never a 486 enthusiast, I had no intentions of doing a build with it....I only kept it for the case....which someone dropped off for recycling years ago.
Anyway, I recently stumbled upon a Supermicro P6DKF AT motherboard and tested it in 'the oven'. I remember seeing one (or one similar) back in the 90's before eATX was a twinkle in anyone's eyes and wondering...-
by shovenoseAlright folks, today I present my latest "build", consisting of mostly spare parts with a few things off eBay.
Parts List and Pricing
CPU: 3/0GHz 4C/4T Intel Core i5-7400. Nothing exciting here, got it off eBay for $80.
RAM: 16GB (2x8GB) Corsair DDR4-2400. Had it floating around. Free.
Motherboard: Gigabyte B250M-Gaming 3. Because I had it floating around and the model number contains gaming so it must be better, right? Free.
Storage: 240GB WD Easystore SSD. As far as I know, it's just the Best Buy rebadge of...-
- Loading...
