The PSU from this post: https://www.badcaps.net/forum/showpo...postcount=1390
It will randomly shut off after 15-45 minutes, doesn't matter the load. Doesn't seem to be heat related. I saw it shut off once with a 50W load after 15 minutes, and it's lasted up to 45 minutes with a 300W load. Loading all the rails, such a strange issue. Soldering side looks good, all new caps. Maybe a partially shorted rectifier?
I want to get it working cause it's a decent PSU. Finally found info on the primary, and they are BJT's rated for 15A @ 25C. Only IC on the whole thing is an SDC2921. Can't find much info on it in English
Any ideas?
Here's the solder side:
Any ideas?
Thankfully, they're all gone now.
Your caps must be good!
Half of the computer problems is caused by bad contacts
