strange seasonic ss650ht voltage drop
  • holmes222
    • Aug 2009
    • 61
    • INA
    hi all..
    have a problem here with strange abnormally seasonic ss650ht
    type is SS-650HT Active PFC F3
    2 unit psu with same type above, act the same symptom
    the problem :
    - psu work ok with connected to motherboard and one sata hdd
    - connected one ata drive dvd, make sata hdd not detected .. 5v voltage drop to 4,0-4,3v
    - disconnect ata drive dvd, connected another sata hdd .. both sata hdd detected .. 5v voltage between 4,5-4,9v
    - connect another sata hdd .. psu power loop .. 5v voltage drop to 0,5v
    - 3,3v read stable at 3,25-3,35v
    - 12v voltage haven't measured yet ..will do later
    physical check show no burnt,bloated,discoloured component
    what's the problem actually here ??
  • DynaxSC
    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
    by DynaxSC
    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
    The board is generally working now, all PCIe ports are working, Windows installs normally.
    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
    03-10-2025, 12:27 PM
  • Instafixx
    Macbook A2179 820-01958
    by Instafixx
    Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
    The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
    I checked the Power Sequences below and found this -
    Once a valid external power source (Charger or battery) is connected, the following rails will come online.
    PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
    PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
    05-20-2023, 05:19 AM
  • digitalDNA
    MOSFET maintains voltage drop across G and S only for 3 seconds
    by digitalDNA
    While trying to fix an SMPS, I hear a ticking sound.
    I've checked all capacitors, but none seem to be shorted.
    I then suspected an issue with the flyback transformer which has 3 leads on the primary (used in a push-pull configuration ?) and one of them, which is always connected to GND has a resistance reading in the order of Mega ohms with any of the other 2 leads on the primary.
    But I thought let's check the MOSFETs first::
    The circuit also contains a PFC circuit, controlled by a UCC3818D (D stands for the SMD version),...
    10-11-2022, 11:00 AM
  • Quaddro
    Seasonic ss-520gb 520 watt voltage drop and bad voltage regulation
    by Quaddro
    i have a seasonic psu model seasonic ss-520gb, with drop voltage and bad voltage regulation
    Measure with digital multimeter,
    Load using my trusty dummy motherboard and 3 hard drive:
    12v rail give 11.35-11.55v with (very) rapid changing.
    And same thing with the other rail.
    But if no load, shorting green and black cable, it can provide up to 11.85v.
    What about the dummy? maybe this one cause error.
    Nope, i've already tested this dummy (motherboard+hdd) with other psu, and still give strong 12v voltage
    04-28-2019, 08:53 AM
  • Fernon@Repair
    Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
    by Fernon@Repair
    i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
    VCCIO voltage ok
    VCCSA Voltage OK
    VCCPLL Voltage OK
    Ram Voltage ok
    RamVTT OK
    VPP 2.5 OK
    But No Core Voltage
    and i want to this vrm ic datasheet or pinout (ISL69269)
    anyone have this ic pinout voltages?...
    06-25-2025, 07:19 AM
