DELL M1730 LAPTOP PSU HA230PS0 - Sparking component - help please
  • Markie76
    • 81
    • United Kingdom - the land of 240v!
    Hi Guys,
    I have a Dell M1730 which is in restricted performance mode and in the BIOS the PSU is showing as unknown.
    The PSU model is HA230PS0-00 REV:A00 and the blue LED comes on and the output is over 19.5v and the laptop powers up - but battery isn't charging (that may due to separate batt issue) and the laptop is in reduced performance mode.
    I opened up the PSU unit to check the continuity of the Dell genuine 'signal' wire and the first thing I noticed was a component which looks like it is self destructing and there are brown marks on the component next to it.
    On the PCB it is marked as 'TH3' and the first time I powered up the PSU open & plugged in to laptop - some sparks came out the top for about half a second.
    Please see pics attached for PSU P/N/specs, TH3 & it self-destructing.
    Before I do anything else I wanted to ask for your help;
    1. Would anyone know/can suggest the part number for TH3?
    2. Does this need to be replaced straight away or it doesn't impact on the overall performance of the psu?
    3. Is failure of TH3 isolated or the result of something else also failing?
    Thx.
    Re: DELL M1730 LAPTOP PSU HA230PS0 - Sparking component - help please
    That is thermistor which is for the in-rush current limiter used in the primary side, it is connected after the Main AC fuse. What resistance does it show right now? You usually do not see this kind of damage, unless there is problem in the circuit which is drawing too much current exceeding the current limit of this device.
    • Markie76
      • 81
      Thank you for your reply and apologies for the delay in replying but I have been away with work.
      The pcb side of TH3 contacts show the following resistance;
      Initial touch -28.5 ohm
      30 seconds - 27.1 ohm
      60 seconds - 26.2 ohm
      120 seconds - 25.5 ohm
      It changes slightly over time but settles at 25.5 if that is significant, I am using a budget UNI-T auto-ranging digital multimeter .
      Thanks,
      Mark.
        That is way too high, at 28 Ohms, with 120V circuit, for 230W power supply, I expect it to around 2~5 Ohms or so when cold, this inrush limiter is the NTC type, as it is heated up the resistance will go down.
        See the calculator:
        http://www.ametherm.com/inrush-curre...t-limiter.html
        http://www.ametherm.com/inrush-curre...ta-sheets.html
        • Markie76
          • 81
          See the calculator:
          Thanks for the reply & links but I'm not getting anywhere.
          Vpeak - the mains is 240v
          Capacitance - what is my capacitance? The psu is rated 19.5v 11.8a 230W
          If you can suggest a suitable replacement thermistor that would be great.
          Thanks,
          Mark.
            Vpeak = line voltage x 1.414, so 240 x 1.414 = 339V, then look at the capacitance value of the main filter cap (there should be big electrolytic cap laying on its side) and put in those numbers in the calculator to find the J rating then look at the that can handle the Joules rating.
            • Markie76
              • 81
              ok, I've delved further into the psu - the capacitor is marked 450v 220uf;
              Vpeak: 339v
              Capacitance: 220 uf
              Total energy = 12.6 joules
              So I need a thermistor rated above 12.6j so something like 15 or 20?
              Also, there is lots of white stuff around components - looks like bathroom sealant but very stiff - what is it?
              • Agent24
                I see dead caps
                • Oct 2007
                • 4977
                • New Zealand
                Glue of some kind. They use it to stop the larger\heavier components moving around during assembly. And if you're paranoid, they also use it as a timed self-destruct feature, when it dries out and can become conductive.
                (Actually I don't know about the white stuff, but the brown\tan stuff often gets conductive with age)
                -David VanHorn
                  What is the diameter of the old one? around 8 mm or 10mm?
                  • Markie76
                    • 81
                    Its a bit tricky to measure but 7-8mm looks about right.
                    The TH3 pcb contacts are about 8mm centre to centre.
                    There's certainly a lot of the white stuff in the psu/case.
                    Going conductive is not very good!
                      This one should be OK: http://www.ametherm.com/datasheets/sl1025002.html
                      25 Ohms (that will limit the Pk current @ 230V (325Vp) to about 13A which the bridge rectifier should be able to handle), 20j, Max 2A steady state (your power supply is rated at 230W, so the steady state with 90% effi will be about 1.1A). This is the closest one I come up with, it will dissipate about 1W of power with 1A.
                      Please note that I do not know what the peak inrush current of this power supply is designed for.
                      You can also contact AMETHERM for verification.
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        The white glue/silicone isn't conductive. Only the tan/brown glue is, but it takes some heat and several years to get to that point. It is also slightly acidic, because it often corrodes traces and terminals on components.
                        That said, the white glue in your adapter is NOT regular bathroom/kitchen silicone. Bathroom/kitchen silicone should NOT be used in electronics precisely because it is slightly acidic as well when it dries and can damage copper traces.
                          Dell XPS M1730 Gaming Laptop Schematic
                          Wistron DS1 Siberia 06248...
                          10-31-2024, 04:05 AM
                        • mikey5791
                          Dell laptop model PP24L won't start from ac adapter
                          by mikey5791
                          Dear all,
                          Bought this used Dell laptop PP24L(studio 1435) in Jan 2022. It was running smooth on 64 bit Windows 7 pro from processor Intel core Duo T6400@2Ghz with 2GB RAM. The laptop battery was charging and working fine until few months back the opening screen will display something like "replacing the battery warning", press F1 to continue. Normally i press F1, the laptop will proceed to Windows and i can use as normal.
                          But last week, after i pressed F1, the laptop just shut down. I suspected the laptop battery is dead. So i pulled out the battery and...
                          03-24-2023, 09:06 PM
                        • Mots06
                          Old Dell E5400 Laptop ( Purchased in the year 2008)
                          by Mots06
                          Hi, I'm unable to find the motherboard number (PPID number) or the board view for this old laptop. My laptop won't start, and when I enter the serial number on the Dell website, it says the number is invalid. The sticker on the bottom is unreadable because it has faded over time. Unfortunately, I'm unable to start the laptop to use the power cell or explore other options.I needed the CMOS Cell & it also seems the Laptop will not start now because of the power switch issue, which is yet to be detected.
                          07-19-2025, 01:56 AM
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • Calidebear
                          Dell 3537 laptop doesn't boot without embedded display.
                          by Calidebear
                          I have this laptop for a long time, still it does it's job, like browsing, word , excel. Two years back laptop Hinge base broken but now it's damaging other parts of laptop so I tried to totally remove the embedded display cable from laptop and tried to boot only with external display monitor, but it doesn't boot and gives single beeps. BIOS checking the embedded display to be connected.
                          So checked the schematics to bypass this issue.
                          Found something but I don't know how to read this schematics.
                          Dell 3537 mobo 9982p rev 3
                          Schematics attached,...
                          03-29-2025, 11:37 AM
