I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before and after the cap replacement
Photo 1 shows the caps that are currently in the power supply and also you can see where i had to repair the trace for the radial cap on the top side. I tried to get replacements as close as possible to the originals
Photo 2 are all the caps before replacement. The caps that were identifiable with a series were mostly panasonic FC. However, there’s the 2x 330u /25v with no series name, 2x 100u /35V and 1x 47u /16v
