klipsch kda-500 amplifier suitable power supply capacitor replacement ?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8351
    Good find! I’ve seen resistors do that. Really annoying it gets when the resistor is cold and has its original value, but then after 10 seconds it goes high in resistance and everything dies. Been there done that. Soooo does this thing work now?
    • r2digital
      • Sep 2011
      • 39
      works like a charm! No more excessive noise from
      the rca jacks/ speaker output and the sound quality is superb. I have 3 now these things and they are absolute monsters… web based gui with eq. if you see a kda500 or kda1000 on ebay that’s not working, do your self a favor and snag one as they can be had for $100 or less in most cases.
      I have not seen a bad amplifier section yet as they have all had issues with the power supply but most repairs only require the replacement of one 16v 1000u filter cap. This was the most difficult one i had to fix to date
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8351
        Awesome! Sometimes it’s a tough go at the fault finding part but the repair itself is usually “easy”.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
        • Goldenmonkey
          Samsung pn59d530a3f no picture after power supply replacement
          by Goldenmonkey
          My samsung plasma pn59d530a3f recently had a loud pop and stopped working. after opening it up, I found a blown resistor and capacitor on the power supply board. The circuit board was damaged where the resistor connects so I opted to buy a replacement board.
          after installing the replacement power supply, the tv powers up but has no picture. The electronics store I bought the power supply from said the next likely culprit could be the Y Main board.
          Is there a way to test the Y Main board before just buying a replacement? Or if there are other areas I should check?
          04-07-2023, 09:39 AM
        • Coert van Dorsten
          Sansui Integrated Amplifier replacement volume control troubles
          by Coert van Dorsten
          Hi all you clever electronmic gooroos!
          I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
          10-15-2025, 02:54 PM
        • Babbar
          by Babbar
          04-12-2024, 01:12 AM
