klipsch kda-500 amplifier suitable power supply capacitor replacement ?
  • CapLeaker
    replied
    Awesome! Sometimes it’s a tough go at the fault finding part but the repair itself is usually “easy”.
  • r2digital
    replied
    works like a charm! No more excessive noise from
    the rca jacks/ speaker output and the sound quality is superb. I have 3 now these things and they are absolute monsters… web based gui with eq. if you see a kda500 or kda1000 on ebay that’s not working, do your self a favor and snag one as they can be had for $100 or less in most cases.
    I have not seen a bad amplifier section yet as they have all had issues with the power supply but most repairs only require the replacement of one 16v 1000u filter cap. This was the most difficult one i had to fix to date
  • CapLeaker
    replied
    Good find! I’ve seen resistors do that. Really annoying it gets when the resistor is cold and has its original value, but then after 10 seconds it goes high in resistance and everything dies. Been there done that. Soooo does this thing work now?
  • r2digital
    replied
    Finally figured it out after taking the entire heat sink assembly out. R35 resistor was reading in mega ohms while it should’ve been a 10k ohm but at the same time while the heatsink wall out i replaced capacitor C15 since the only time you can get to it is with the wall out. All capacitors on the power supply and the main input output board have been replaced
  • r2digital
    replied
    https://datasheet.octopart.com/FDC65...et-8322017.pdf
    It has all the proper voltages near by except gets messed up at the 55BZ chip and i think the above pdf is a replacement for the 55BZ. There is nothing on the bottom of the board that is connected to this chip. Attached is a trace of its path for the 55BZ. C24 negative path is not connected to the nearby 55BZ. Pins 1 & 2 are connected to the same trace and pins 5&6 are also connected together
  • CapLeaker
    replied
    Looks like the negative is having a through hole to the other side side of the board. Where does it go? It’s got to be connected to something else somewhere? Do some more tracing.
  • r2digital
    replied
    purple line shows where the trace starts at the yellow wire and ends at the negative trace of capacitor 35v 47U capacitor and should be -13-14VDC
    Removed cap for better view
  • r2digital
    replied
    I have a working KDA1000 which i opened up to compare voltages to so maybe some one can point me in the right direction.
    kda500 power supply not working
    right to left
    4 pin
    brown 8.06
    black 7.93
    white -0.11
    gray -0.10
    5 pin
    green 30.16
    blue 3.29
    green 2.58
    red/white 3.01
    red 1.11
    3 pin
    yellow -.759 <—— this should be -13-15VDC
    light blue -0.024
    yellow 13.78
    3 pin
    black 165
    brown -166
    red -165
    Kda1000 operating normally
    4 pin
    brown 8.52
    black 8.92
    white -0.003
    gray - 0.003
    5 pin
    green 32
    blue 3.33
    green 2.6
    red/white 3.05
    red 1.1
    3 pin
    yellow -13.7
    light blue 0
    yellow 13.8
    3 pin
    black 157.5
    brown -157.8
    red -157.8
    55bz<—- need help identifying what this is as it is not giving me proper voltages
    these are the measurements from the working power supply
    1 -18.2
    2 -18.2
    3 -5.83
    4 -18.71
    5 -18.71
    6 -18.71
    The measurements from the non working power supply 55BZ chip were very low
    1 0.380
    2 0.380
    3 -20
    4 0.420
    5 0.400
    6 -20
  • r2digital
    replied
    I wish i was posting with a complete fix of the power supply but i am making progress. After the replacement of the switcher it now turns on and stays on between 1 and 8 attempts. Unfortunately when it does comes on all the 4 channels in the front light up detecting there's audio even when nothing is attached . However, i found that Q2 is the culprit of the random starting of the power supply. Does this seem like a suitable replacement https://www.mouser.com/ProductDetail...A%2FBgJw%3D%3D ?
  • CapLeaker
    replied
    I've got quite a few good stories about these 5 legged switches in that package. This is the worst designed switcher ever, Just make sure to clean, clean and clean that area again. It's got to be hospital grade clean. No stuck lint from a paper tower or swabs, flux etc.
    Take that switcher off and wash that whole area with 99 % IPA a few times.
    Good luck!
  • r2digital
    replied
    Yup! you were right all along so thank you again for your help. I’ll post back in a few days with an update once i get a replacement in but i swear i never even touched that thing
  • CapLeaker
    replied
    Just as I mentioned in my post #3! These 5 legged devices always have been a problem source.
  • r2digital
    replied
    ok, i have a pretty good update. I used some freeze spray on the 5 leg TOP265EG and the power supply started and stayed in stand by a few times but also a few times it turned it self completely on and was detecting signal present with in all 4 channels.Im almost positive it is bad
  • r2digital
    replied
    I checked several times, there is no rectifier there. It goes from that positive cap trace that was repaired directly into the transformer. I was able to check for continuity from the transformer pin on top to the repaired trace on the top of the board
  • CapLeaker
    replied
    There should be a rectifier after the transformer then the cap.
  • r2digital
    replied
    I tried resoldering the positive lead of the cap to pin 1 on the transformer which is where the trace goes but still no luck
  • r2digital
    replied
    right to left
    4 pin
    brown -8.4v
    black 7.6
    white -.006
    gray -.006
    5 pin
    green 32
    blue 3.3
    green 2.6
    red/white 3.0
    red 1.1
    3 pin
    yellow .770
    light blue -.016
    yellow 13.5
    3 pin
    black 165
    brown -166
    red -165
  • r2digital
    replied
    there is a rocker switch for main power that turns the amp on directly into standby(solid red light) when in standby the amp is able to be managed through a web gui. The amp is currently configured to turn on by audio sensing 5mv but could be changed to always on if i was able to get the power supply going again. I didn’t hear any loud noises or bangs so i was pretty surprised when it wasn’t working after the cap replacement. I will double the voltages when i get home later today but does the trace repair look suitable or should i try to solder the cap to the top side or the board ?
  • CapLeaker
    replied
    O.k, sounds like it has a problem with one of the output rails of the secondary. If there would be something wrong with the primary, it either would be dead, or it would went out with a nice BANG! Somehow there has to be a STBY voltage and hopefully that isn’t clunking out.
    Measure all the voltages on the secondary side of the PSU and make sure they are there, How does this PSU turn on? Is there a switch somewhere or does it turn automatically on and off like a powered speaker?
  • r2digital
    replied
    It looks like it’s isolated because i used some solder mask after the trace was repaired so i could definitely see how it looks wrong lol and i wish i had a more clear pic to show for that. The backside of the board had nothing left to solder too but luckily the trace in the center on top next to where the radial positive lead goes was also on the bottom side of the board so i bent the radial cap lead over to that and soldered it. But now im questioning if that will even work? I was over by that 5 legged device with flux and i even bent that little board out of the way a tiny bit so i could solder on the capacitor nearby with out issue. The red light comes on and i hear the power supply making some noise but after a few seconds it shuts off and keeps attempting to turn on repeatedly. I attached some more pictures of the board
    Edit : Removed radial cap for clear pic of trace on top of board
    Last edited by r2digital; 04-18-2024, 09:31 PM. Reason: removed radial cap and added pic
    by sam_sam_sam
    03-31-2024, 02:12 PM
  • Goldenmonkey
    Samsung pn59d530a3f no picture after power supply replacement
    by Goldenmonkey
    My samsung plasma pn59d530a3f recently had a loud pop and stopped working. after opening it up, I found a blown resistor and capacitor on the power supply board. The circuit board was damaged where the resistor connects so I opted to buy a replacement board.
    after installing the replacement power supply, the tv powers up but has no picture. The electronics store I bought the power supply from said the next likely culprit could be the Y Main board.
    Is there a way to test the Y Main board before just buying a replacement? Or if there are other areas I should check?
    04-07-2023, 09:39 AM
  • Coert van Dorsten
    Sansui Integrated Amplifier replacement volume control troubles
    by Coert van Dorsten
    Hi all you clever electronmic gooroos!
    I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
    10-15-2025, 02:54 PM
  • Babbar
    by Babbar
    04-12-2024, 01:12 AM
