Mecer lobo 1200 /VR-1200BKS Not switching on
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Click image for larger version  Name:	20240321_152026.jpg Views:	0 Size:	1.40 MB ID:	3239787 Hello guys,
    I'm a TV tech and a friend has asked me to look at his Mecer inverter. I haven't connected a battery but plugged it in to the mains and it does run a lamp. The lcd screen is not illuminating. My friend says he mistakenly connected the battery reverse polarity but the Mecer site says it has reverse polarity protection and that I should check the fuses. The fuses check out ok and there is no sign of damage to most of the component's I could check with my meter. I had removed the transformer and heatsinks to check print underneath. Where do I start? Thanks, Mike
  • Grunder
    • Jan 2016
    • 323
    • south africa
    Hi Guys, another customer who does pv work says he's had the identical unit with the same problem which he took to the local Mecer agents and they returned the unit unrepaired, not worth repairing.
    This unit looks brand new and with Mecer saying that it has reverse polarity protection and the fact that it should be able to handle power interruptions one would think it would have not failed so prematurely? Like a bulldozer with a glass bumper. Doesn't say much for the brand. Thanks, Mike
      • 31183
      check the 5v or 3.3v at the lcd or microcontroller,
      if it's missing you can trace it back
      • Grunder
        • Jan 2016
        • 323
        • south africa
        Thanks, will do
        • Grunder
          • Jan 2016
          • 323
          • south africa
          Thanks Stj, alot of switching going on and without a better oscilloscope I've decided to RNR the unit. That with the agents also saying it's kaput. Time to upgrade and do a bit of swatting
            by sam_sam_sam
            03-31-2024, 02:12 PM
            by sam_sam_sam
            07-01-2024, 06:34 AM
            MSI Gaming GT73EVR 7RF-1200 Titan Pro Notebook GT Specification for Upgrade or Repair
            This specification for the MSI Gaming GT73EVR 7RF-1200 Titan Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT73EVR 7RF-1200 Titan Pro boardview and GT73EVR 7RF-1200 Titan Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
            09-06-2024, 06:30 AM
            by sam_sam_sam
            After all of...
            07-13-2024, 08:14 PM
            DVR camera recorder switching power supply capacitor failure really
            by sam_sam_sam
            These cheap non brand capacitors at it again
            Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
            Well at least I have the cameras back on line I to try the...
            01-22-2022, 06:28 PM
