How to troubleshoot dead power brick
    • 31070
    32ohm between gate and source.
    lets see, source voltage is 170v
    max gate voltage on most mosfets is 30v
    chip is bad and mosfet is in question and where is the 10k coming from?
    • CapLeaker
      Leaking Member
      • 8202
      mmartell
      that sounds to me the OB2269 is fubar. Even so the pads measure up without the chip, recheck the whole gate drive and the mosfet. Usually the mosfet fails and dumps high voltage to the gate drive. But sometimes the IC fails and everything else is o.k. Not sure where the 10k come from either.
      Kinda on the rare scale, but seen it before.
      • mmartell
        • Oct 2013
        • 3189
        See pic - R5 is a 10k resistor between Gate and Source that's where it's coming from. I also measure 13.6 ohms between pins 6 and 8 on the power ic itself now that it's out of circuit.
        Not sure how to test the mosfet it's not shorted in any way at rest but could be open I guess ? Reads as a transistor from D to S with my meter but that's all I get out of it.
        Can this power ic be substituted with something more common ?
        • CapLeaker
          Leaking Member
          • 8202
          The OB2269AP is actually quite common. Even LCSC and many others have it, just not Mouser or Digi.
          Pin 6 is the sense pin and pin 8 is the gate pin. That’s why I am saying check out the whole gate drive circuit!
          • Andreas_de
            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
            by Andreas_de
            Hello!
            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
            04-12-2025, 10:38 AM
            by sam_sam_sam
            03-31-2024, 02:12 PM
            09-06-2024, 05:59 AM
            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-12-2024, 02:15 PM
            HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation Specification for Upgrade or Repair
            This specification for the HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Power 15.6 inch G9 Mobile Workstation PC boardview and ZBook Power 15.6 inch G9 Mobile Workstation PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
            09-07-2024, 05:20 AM
