Power Board Ic Identification
  • garrymc123
    • Apr 2010
    • 336
    Hi there
    Looking for some advice i have this power board out of a dj light and it had no power so checked fuse f3a which was blown so checked diodes and one had failed so changed it but have a Zennor diode fail also ZD1 not sure what code is on it the main problem is trying to identify ic Q1 s its all scored off on the board it says 6n60 had a google but couldn't find anything
    Any Help Appreciated
    Your never to old to learn
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8133
    Lemme see...
    ZD1 = 15V zener diode. Make sure you get the same diameter.
    The diode you circled black is a HER107. This diode is ultra fast.
    About Q1: The package is called TO-220F-6L
    I suggest you find the little plastic pieces so we can narrow the part number down more. I can see that it did start with a DM xxxxxx. And I can see an E above that part number. A quick search on Ali revealed this:
    DM0565R / FSDM0565RE
    also a
    DM0465R that could fit.
    https://www.aliexpress.com/item/1005...Cquery_from%3A
    Check what you find, vs what I came up with.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      Mitsubishi CNC switching power supply board dead / relay board bad diode failure
      I was working on this CNC machine today found no keyboard functioning no control relay powering on
      The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
      Found shorted diodes on main controller relays there are 3 of them that...
      01-07-2023, 05:43 PM
    • Destroyer-Br
      [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
      by Destroyer-Br
      I'm working on an Acer Nitro 5 unit with the following specs:
      • Motherboard: LA-J871P Rev: 1B
      • Model: Acer AN515-55-59MT
      • S/N: NHQ7JAL00403906A973400
      • SNID: 03902728734
      Initial Issue
      The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
      After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
      04-17-2025, 08:18 PM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
      After all of...
      07-13-2024, 08:14 PM
