Cosel ZUW25 2415
  • JJ_
    • Oct 2023
    Cosel ZUW25 2415
    I took this off a donor board. I am trying to see if the unit is functional. I tried giving it power 30V. applied to V+ and V-.
    I could not get an output. I checked for output on V+ V- and combinations thereof with COM.
    The board is potted. Does anybody know how to test these for functionality?
    Here is the datasheet.
    https://en.cosel.co.jp/product/power...W25/ZUW252415/
    Thank you to all in advance who choose to help.
  • прямо
    • Sep 2022
    • 261
    • Indonesia
    It's a 24V to +/-15V DC converter, so why did you power it from a 30V source? You most likely killed it.
    • lti
      • May 2011
      • 2547
      It's rated for 18-36V, so 30V is fine.
      There is a remote on/off pin that needs to be grounded to enable the output. Have you connected that pin?
      • JJ_
        • Oct 2023
        Thank you for the response. The datasheet says you can go up to 36 V.
        • JJ_
          • Oct 2023
          Thank you for the response. I did ground it by connecting V- to the RC pin. I get absolutely nothing. Unless that's not how you ground it.
          • FrancescoV
            Onkyo HT-R390 no sound output, video output ok
            by FrancescoV
            Good morning everyone,
            I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
            The firmware reported is the following:
            M:1.00/11107BLP
            D:?.??/????????
            O:1.00/11107AL
            The DSP firmware given the question marks seems corrupt.
            On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
            05-11-2025, 02:59 AM
            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
            I bought this from an eBay seller but unfortunately they only had one
            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
            I bought three of from them to also make battery packs with this output power limit in mind
            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
            04-23-2025, 05:50 AM
            Corsair CX750M [Model 75-002019] - burned output toroid inductor
            by momaka
            Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
            So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
            09-19-2021, 08:44 PM
          • CoppellTVRepair
            Troubleshooting PFC with SPC1012T not raising output
            by CoppellTVRepair
            It has been a long while since I posted here to ask anything....hope you can help.
            I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
            I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
            03-09-2025, 10:38 PM
          • flibidy
            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
            by flibidy
            I have here a Magnum IA.100 which belongs to my parents.
            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
            What Ive done........
            01-01-2025, 01:26 PM
