UC3842 Power Adapter Blowing Fuse
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
    Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the original adapter to have a look inside, just in case it's something really easy to fix.
    It seemed simple at first, but ended up being a rabbit hole: what happened is I shorted the output for a few seconds by accident on a metal surface. I noticed the LED was not coming on and I began investigating, but by the time I noticed what the cause really was, I heard a small "poof" and that was it. Cracking the case revealed 2 (or 3, not sure, since one may have been completely pulverized) destroyed current sense resistors on the source of the FET. Although they were charred, they were still decipherable - 2R2, so 2.2 ohms each. The FET and IC were also dead. I didn't have the exact transistor on hand so I used something equivalent out of my junk bin. Same goes for the resistors: didn't have them, much less so in SMD form, so I botch-soldered a single 0.82 ohm one on there hoping it'd be close enough. Output diodes were also shot - replaced those too....this was getting out of hand at this point, but I pushed on nonetheless.
    Where I stand now: running it in series with a 25w bulb on the mains side, as usual, produces the correct output voltages (12v and 5v), but the bulb glows too much, hinting it's drawing too much current. I tried it without the bulb just to confirm and it indeed blew the fuse. Thankfully, it didn't kill any parts, so it wasn't a violent current draw, but not functional either.
    Having replaced virtually everything that could be bad (even the main cap), my money is left on the transformer itself having a shorted winding inside, which is a lost cause at this point, since I'm clearly not going to find a direct replacement for it.
    Things I'm not entirely sure about: I'm not sure whether there were 2 or 3 current sense resistors. I assumed there were 2 and went with that 0.82ohm resistor. I tried it with a 0.5ohm resistor and the same behavior occurred.
    Second, is there a difference between a UC3842AL (original) and the UC3824B that I used ? I couldn't find any difference in the datasheets myself, so I doubt it.
    Third, can bad output diodes cause this ? "Leaky" ones, since shorted ones can definitely can. I didn't have new diodes and they are also not the same type: the originals, if I remember correctly, are SR540 and I put in a pair of SR515 which I concluded sure should work after going over the datasheet.
    Any ideas ? It's probably heading towards the trash bin (after I recover all of the useful components that I spent so much time soldering in) ....
    Wattevah...
  • vieuxchoub
    • Oct 2017
    • 34
    • france
    Dear Dannyx
    You should borrow an infra-red camera and your board under it to get some clues while using your protective bulb.... For sure, the short will get hot under the thermal cam....
    You close to solve this repair.... Keep going on!!!!!!!!
    • petehall347
      • Jan 2015
      • 4450
      • United Kingdom
      might be the light but D5 looks broken to me
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Surprised you even managed to see the D5 mark in the first place but no - diode's fine.
        Ok, problem solved. Take a guess what the big problem was.....seriously, can you guess what the magic component was ?........give up ? Ok, it was the bridge rectifier all along. You can tell it's been ages since I've fixed a SMPS. I forgot to check the most basic of things. Ok, I sort-of checked it, though no thoroughly: I just ran my probes across it and got nothing, so I just assumed it's all good, but it turns out the damn thing was shorted on just ONE of the diodes: AC leg to + leg, which I discovered by pure accident, so my primary was running on half-wave DC
        Wattevah...
        • Tips
          Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
          by Tips
          Looking for some assistance please.
          Trying to repair a PD27AOQ samsung power board.
          Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
          Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
          Testing it the fuse blows immediately power is turned on.
          diodes dm852 and dm853 test as shorted when in the board but fine when removed.
          any assistance, guidance would be appreciated.
          04-11-2024, 11:24 AM
        • RogerH58
          Samsung 46" TV LE46B530 blowing fuse
          by RogerH58
          I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
          I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
          I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
          06-10-2023, 10:27 AM
        • corrize
          A funny fuse story – Lumix LX100 II
          by corrize
          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
          10-19-2023, 09:58 AM
        • repair-it
          TOSHIBA DLP 52HM95 How to reset timer module on bulb
          by repair-it
          I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
          Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
          10-11-2023, 07:18 PM
        • ezenia
          LUMIMAN Smart Bulb IC ID?
          by ezenia
          I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
          In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
          04-28-2025, 05:56 PM
