Thermaltake Pure Power 600W +5VSB problem
  • JohnStark
    • Dec 2013
    • Moldova
    A few days ago I found my PC shut down though as usually I put it in standby. First thing I found the green power LED on motherboard was blinking fast. After some inspections I found that the problem is in PSU. I have a Thermaltake Pure Power 600W PSU and till that day it worked perfectly.
    When I checked voltage on +5VSB wire there was ~3.4V. After shutting down PSU and connecting to power after a while it has normal 5V on the line, but once there is some load (~0.5A) voltage drops and a LED connected to this line will blink with about 20Hz rate and there will be a low frequency ticking in the PSU. Turning on PSU with PS_ON wire starts it with all voltages in their normal values under load (still +5VSB will behave in the same way).
    I started to dig up the problem, but I couldn't find some reference point. Another problem is that PSU have a compact parts placement, dual layer PCB and a high temperature melting solder and is not quite easy to take out parts from PSU to check them or to see how components are connected and I don't really want to disassemble it completely if the problem can be found without that.
    Can you give some directions on what can be the problem of this behavior?
  • Khron
    • Sep 2006
    • 1350
    • Finland
    Re: Thermaltake Pure Power 600W +5VSB problem
    Is it just my imagination or a shadow, or is the 5Vsb filter cap bulging? Second picture, to the left of the uppermost red-heatshrink-wrapped common-mode inductor, right next to the small transformer. What brand is it, by the way?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
    • JohnStark
      • Dec 2013
      • Moldova
      It's a SAMXON 2200uF x 10V and, yes, it's a little bulged...
      • JohnStark
        • Dec 2013
        • Moldova
        Well, is seems that the problem was in that cap. I changed it with a new one and now PSU and PC is working as usual. Is it possible that it went out because of many USB devices were connected to PC and it was mostly in standby?
        • Khron
          • Sep 2006
          • 1350
          • Finland
          That may well have been the case, but it also depends how the mainboard was configured to supply power to USB devices, either from the main 5V rail or the 5Vsb rail. Check either the BIOS settings or the manual (in case that's set via jumpers near the USB ports/headers).
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Hmm, what series is that Samxon? It doesn't look like GF or GL, which are the ones I know are bad. Also, what did you replace it with?
            • c_hegge
              • Sep 2009
              • 5219
              Ive had a similar power supply do the same thing (although in my case, it killed the motherboard). The fact is, it's a junk Samxon GF cap, and it's gonna fail regardless of how it is treated.
              • TELVM
                • Oct 2012
                • 547
                • Spain
                Is this the critical +5VSB cap you guys always talk about that can kill the mobo when it fails?
                • Wester547
                  • Nov 2011
                  • 1268
                  • USA.
                  ^ No, that's the output filtering capacitor for +5VSB, or at least the one before the ferrite coil in the output filter as a whole. The critical capacitor is found on the primary side, after the +5VSB transistor. It is much smaller and is usually a 2.2uF (minimum) to 220uF (maximum) GP capacitor or somewhere in between (usually the case).
                  • TELVM
                    • Oct 2012
                    • 547
                    • Spain
                    Thanks Wester!
                    • senz_90
                      • Aug 2013
                      • 328
                      • Indonesia
                      is there any way to prevent this critical 5VSB caps to kill motherboard? or just replace it with a well known caps?
                      "There is no shortcut to be successful. No pain, no gain."
                      Best Regards
                      Rudi
                      Thank You
                      • c_hegge
                        • Sep 2009
                        • 5219
                        You can either replace it with a reliable Japanese part, replace the whole 5vsb circuit with a PWM IC driven one, or put 1W 5.5V Zenner diode across the output, with the stripe facing the positive. If the output goes higher than 5.5V, it will conduct the excess over to ground. If it really goes south, the Zenner will short and blow up the switching transistor, but it won't take the motherboard out.
                        • senz_90
                          • Aug 2013
                          • 328
                          • Indonesia
                          I miss this thread and just realize it now!! sorry.
                          it will be easier to use zener diode. but im curious about pwm ic that you have mention. does it mean attach a new circuit on new pcb that driven by new pwm ic or just from the psu pwm ic itself?
                          Best Regards
                          Rudi
                          Thank You
                          • c_hegge
                            • Sep 2009
                            • 5219
                            https://www.badcaps.net/forum/showthread.php?t=6680
                            I meant something like this. everell has done it plenty of times.
                            • senz_90
                              • Aug 2013
                              • 328
                              • Indonesia
                              Thanks c_hegge. I will see it.
                              Best Regards
                              Rudi
                              Thank You
                              • thesame
                                Pure Discovr Bluetooth speaker not charging possible bms problem.
                                by thesame
                                Hi guys i'm posting here because I think that there's a battery or BMS issue even do the problem is with a pure discovr smart speaker found with one battery at 1.6v and the other at 3.2 v not drawing any current from the type c port. The speaker was new and unused , my guess is that the BMS is somehow in protection mode or something, I have tried to disconnect the wires from it charge the batteries from the lab PSU and reconnect them and still not charging after that.What should I Try? I also bought another bms that you can see in the pictures but i have this white wire coming from the usb type...
                                06-30-2025, 01:35 PM
                              • theone111
                                by theone111
                                3. Problem: TV shuts down
                                07-22-2024, 10:36 AM
                              • Nabri
                                BeQuiet! Pure Power 9 CM 700W +5VSB only
                                by Nabri
                                I’ve been trying my best to repair a power supply I have recently bought, but I’ve had no luck with it as I can’t find any schematics or board views online for this specific model.
                                The current issues are as follows:
                                if I short the PS_ON pin to ground, a relay will click and the fan will spin for 0.1 seconds, and then nothing else.
                                I could not find any blown components or IC’s inside, but measuring all the output pins has led me to a conclusion of sorts, I only have +5VSB and all the other power rails show a very small voltage, like, 0.30V,...
                                09-22-2024, 11:08 AM
                              • Zeonalbasta
                                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                by Zeonalbasta
                                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                09-13-2024, 01:17 PM
                              • Gibon378
                                Problem with stopping audio and video for no reason
                                by Gibon378
                                PC Specs:
                                • CPU: Ryzen 5 1600
                                • GPU: GTX 1080 Palit JetStream
                                • MOBO: ASRock ab350 PRO4
                                • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                • PSU: XFX 650W (don't remember what model)
                                • OS SSD: ADATA SP920
                                • OS: Windows 10 21H2
                                Problem description:
                                Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                11-19-2022, 09:41 AM
