Aspire PSU with bad caps
  • VisciousSquirrel
    • Mar 2007
    I have an Aspire ATX AS-520W with 2 capacitors that are bulged and one of which was starting to leak. The PSU still works, but Ive decided to replace the capacitors to ensure the longevity of it. Question is, should I just replace those two, or should I replace the rest as well?
    The brand is Y.C, the larger cap is 2200uf at 10V (~10mm) and the smaller one is 1000uf at 10V (~8mm). I was thinking of replacing them with these:
    http://www.newark.com/jsp/Passives/A...sp?sku=69K7927
    http://www.newark.com/jsp/Passives/A...sp?sku=69K8202
    Will those work and are they a good brand?
    Here is a pic with the bad caps marked for reference:
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Aspire PSU with bad caps
    I would replace all caps except the bigg 200v ones.
    The KXM caps you linked should be fine, the others are not LOW ESR types, wich will not a lasting choice (besides some other problems ).
    My suggestion would be to stick with UCC caps, Rubycon or Pnanasonic.
    • VisciousSquirrel
      • Mar 2007
      I did a careful inspection and all the other capacitors appear to be fine. Would it be worth the trouble to replace them all, or would replacing just the failing ones be ok?
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        If you really really like Newark, stick with United Chemicon, LXZ, KY, LXY or KZE series in that approximate order of preference (I don't know off the top of my head which of those series Newark carries. otherwise, look into Digi-Key, which carries UCC, all four of those series, Nichicon PW or HE series and Panasonic FC and FM series.
        PeteS in CA
        • larrymoencurly
          • Oct 2004
          • 960
          How did you inspect them? I had a 300W Antec where one of the caps on the +12V rail bulged, but the other one looked and showed low ESR. But a few weeks after I replaced the first cap, the supposedly good cap bulged and its ESR went way up.
          • hardwareguy
            • Jun 2006
            • 405
            The caps on that aspire look just like the caps I replaced on a friend's aspire PSU. The PC had the classic bad power symptoms too, spontaneous reboots, odd BSODs, disk corruption, and startup problems.
            It works fine now that a nice Rubycon cap has been added in place of a bulging one on the 12V rail.
            • B3Nut
              • Apr 2007
              • 7
              If you don't replace the other secondary caps now, you'll replace 'em later. Aspire/Apevia PSU's are loaded with Y.C. and/or Fuhjyyu caps, and they get quite hot and then vent. Young Year is the OEM for their supplies...they're not really known for longevity.
              Personally I don't think they're worth the effort to repair, I just recycle-bin 'em when I run into them. But if you want to keep that one around, a recap will at least make it reasonably reliable.
              Todd in Cheesecurdistan
              • hardwareguy
                • Jun 2006
                • 405
                Total O/P recap will be done on my friend's aspire this summer.... it's one of those slightly short ATX supplies, a full size would be a TIGHT fit in his little aspire "cube" case. Gonna get on Digikey and get some good Matsushita caps for it. I wish we could easily fit a full ATX PSU, but it would be a cable disaster if we did.
                I HATE Fuhjyyu!!!!! Although, they have made me a bit of cash, most of them have been in friend's PCs! The most money has been made yanking GSCs..... Gigabyte has been affected quite badly by these, their socket A boards especially. Cap inspection is done as mere routine..... even if the machine seems to be working fine.
                • B3Nut
                  • Apr 2007
                  • 7
                  Yup, we have dozens of those Aspire/Apevia cube cases. It's indeed tight installing a standard ATX supply, but the stock short one is so bad it's worth the contortions to install a good one. I have good success with FSP Blue Storm 400's in these, the cables are not too difficult to get out of the way. I've shoved leftover PC Power&Cooling Silencer 410's we have in with good results as well, I have an Aspire cube with a Silencer 410 on my desk at home (it's my Windows Home Server Beta test box).
                  JonnyGURU tested the shorty that comes with the X-Qpack cubes, although rated at 430 watts it maxed out at 266 watts before the overcurrent protect tripped. Not only are the caps cheap in these, the design is so overrated and underbuilt it's not IMO worth putting anything into. Shoehorning in a standard ATX supply is a bit of a chore (not as much if building from the naked chassis up) but it's worth it just to be rid of the stock supply. Our recycle bin's got a bunch of those Aspire/Apevia shorties piling up in it, and as more that are in service start going south the pile will be growing.
                  It takes a little creativity, but having a more robustly-built supply is worth the hassle IMHO...YMMV...
                  Gigabyte's using Fuhjyyu caps on their motherboards? Yikes...we're an all-Intel shop so I don't get to see other manufacturers' boards that often...though I'm contemplating an Asus Socket AM2 board for my own non-work-related tinkerings...
                  • Azurael
                    • May 2007
                    • 25
                    Another Youngyear ATX-66B-based PSU then? (joining the ranks of the X-Connect 500W)
                    Mine has Fuhjyyus though.
                    • B3Nut
                      • Apr 2007
                      • 7
                      Yup, that looks like an ATX-66B board, I found this interesting article:
                      http://www.hardwaresecrets.com/article/413
                      The in-depth analysis starts off with "The design used on this power supply is simply ridiculous." After reading the text, I concur. The same NPN primary transistors and anemic primary rectifier bridge show up in the "430W" short-ATX wreck that comes in the Apevia cube cases. Young Year seems to turn corner-cutting into an art form...a rectifier on the 12V secondary that can only pass 10 amps? No wonder the damn things overheat and toast caps...
                      That article was an eye-opener...I see no reason to repair a dead one, even with good caps those undersized rectifiers aren't going to pass anywhere near the rated current. You'll just be shifting the failure points from the electrolytics to something else. I wouldn't connect one of these to any hardware I cared about, but that's me.
                      TP
                      • Azurael
                        • May 2007
                        • 25
                        I did read that article, much to my distress, but I've never had any trouble running pretty heavily loaded systems off that PSU - it was in my main rig until I built the current C2D system (which needed a 24-pin ATX connector) and I've never seen the +12 line go below about 12.2v...
                        I even ran a system with a heavily overclocked 6800 Ultra and Northwood 3.06 & 3.5GHz off of it and it didn't flinch under load, so either not all ATX-66B PSUs are built with the same, under-specced components or I am one very lucky person to get a 10A rectifier that has no trouble passing a lot more than that.
                        • hardwareguy
                          • Jun 2006
                          • 405
                          Ok.... crap! I have been given a budget of 15 bucks to fix this puppy! That of course means no nice Seasonic PSU going in this guy's PC. The PSU is a hunk of garbage, but at least it's better than those Deer units!
                          Here's how I am going to "repair" the PSU:
                          All the Fuhjyyu caps are being desoldered and thrown out.... my friend may get a little fun time with the hammer if he so desires. I changed out a couple of the caps that were bad, but I ran out of caps so as soon as the next batch comes in, it's being totally recapped.
                          The input caps are undersized with just 330 uF capacitance. He now has a nice set of 820uF caps, now it doesn't reboot when the momentary brownouts hit.
                          The 12V rectifier is being changed out. There IS space for a nice fat TO247 package rectifier on the board...... and guess what I just happen to have in pristine condition on the shop bench.... a nice TO247 30A rectifier. I'll put this in at the next recap.
                          The tiny MOV across hot and neutral will be replaced by a fat 130J unit. I will probably put in a Littlefuse TMOV unit.... these have thermal cutouts integrated into them to prevent fires. As it stands now, the MOV has no thermal cutout placed in series with it or even a simple fuse. UL would be pissed if they saw that! (I suspect the Fire Marshall would be a bit peeved too!)
                          When he gets some cash, he may replace the PSU but right now he's a bit strapped. I just told him that he needs to put a new set of pads and rotors on his Jeep.... 90K miles on the original pads and the rotors are warped. Yikes!
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            had one of those in here yesterday.had a hole burned in the board.
                            maybee assfire is a more fitting name?
                            • BigTroll
                              • Sep 2010
                              • 1317
                              • LAMBDA SOND
                              I also have a 66b pcb power supply labed ATX-AS500W its aspire brand. that hardware secrets review doesn't reflect all the models, mine has a thermistor and the second ferrite thing my heatsinks look alot beefier too. i bought mine used from my friend back in 2007 and have run it 24/7 for months at a time, it had no problem powering a e8400 cpu and a 8800 GTS 320meg
                              anyways i tryed to include in the pic the two fuhjyyus that are leaking 1 is a 1000uf 10v and the other a 2200uf 10v, i was thinking of buying some samxon replacements for those two caps from this site? do you think they would work?
                              also on the second pic theres some weird upright thing that seems to have its casing split in the middle its not a capacitor so iam not sure what it is.
                              My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                              • 370forlife
                                Large Marge
                                • Aug 2008
                                • 3112
                                Samxon will work just fine. Generally most power supplies have 2 16v caps on the 12v rail, 2 10v on the 5v, and two 10v or 6.3v on the 3.3v rail. Could you confirm this? If this is right, you could just get two of these (https://www.badcaps.net/store/produc...products_id=56) for the 12v rail, and four of these (https://www.badcaps.net/store/produc...products_id=57) for the 5v and 3.3v rail. Then it would also be wise to replace the caps on the 5vsb filter.
                                And whatever the second pick is looks it's screwed to the heatsink. Is it? If so it might be a primary switcher, but you would have to desolder the heatsink and take it out to get the part number and install a new one. Either that or it's the rubber sleeving getting ripped up or burnt off on those big resistors in the primary sections of power supplies.
                                • BigTroll
                                  • Sep 2010
                                  • 1317
                                  • LAMBDA SOND
                                  yeah it looks like a rubber sleeve and the top and bottom parts are still there just not the middle as some of the sleeving flaked off, its not attached to the heatsink, oh yeah this power supply still works.
                                  • BigTroll
                                    • Sep 2010
                                    • 1317
                                    • LAMBDA SOND
                                    okay after letting it sit a few years i finally took it apart and replaced both leaking caps 1 with a used 2200uf 10v nichicon from a 1999 athlon xp and the other a rubycon 10v 1000uf from a 2004 hp p4 board. now the power supply is working great again. and has manual fan control which keeps the old fuhjyyus cool voltages are great and its powering a athlon xp rig with bloated GSC capacitors all over it. i figuere shit should power shit.
                                    • BigTroll
                                      • Sep 2010
                                      • 1317
                                      • LAMBDA SOND
                                      this power supply is still working great ive upped the anti and now have it powering 6 cold cathodes, led programable fans 8800GTS 320MEG G80, 2.4Ghz AMD OPTERON 180 and do long gaming sessions of the new black mesa at 1600x1200 max everything.
                                      • BigTroll
                                        • Sep 2010
                                        • 1317
                                        • LAMBDA SOND
                                        THEM BIG 820UF 200v FUHJYYU JUST CHANGED MY LIFE they KEEP ON GOING FUHJYYU FOREVER! MAKIN LIFE BETTER AND BETTER.
                                          ACER Aspire Aspire X3910 Aspire E5700 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire X3910 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X3910 boardview and Aspire Aspire X3910 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-12-2024, 03:36 PM
                                          ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:30 PM
                                          ACER Aspire Aspire XC-330 Aspire XC A4-9120e Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire XC-330 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-330 boardview and Aspire Aspire XC-330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          ACER Aspire Aspire TC-886 Aspire TC i7-9700 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire TC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire TC-886 boardview and Aspire Aspire TC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
