Artic Power 950w - Not 100%
  • domas
    News Hater
    • May 2013
    • 323
    • Denmark
    Re: Artic Power 950w - Not 100%
    Originally posted by quattro alex
    I've just tested the diodes and found D5 (UF1007) to be shorted ( I get a reading in both directions). Should I replace with the same or go up a notch?
    Also can you confirm what you mean by switchers please?
    I managed to get around 330v at Q6 but not Q5 does this help at all?
    Yes I am very much a fan of AWD and I am on some of the car forums. But if you want to make the most of that system you need the right rubber... Dunlop wintersport 3D's when it gets cold enough
    +1 on Behemots post.
    Switchers = primary transistors on primary heatsink (HV or hot side )
    I don't see the diode you are talking about as i am in rush right now, but desolder it and check it again for accurate reading. I would just replace it with similar value, from, lets say, another scrap SMPS. But please do check components around to make sure it doesn't destroy same components again after powering up.
    //unrelated:
    okay so i was right )
    i use nokian hkpl R for winter driving ) does the job.
    • Behemot
      • 4845
      • CZ
      Oh, I looked again and find the diode. So it has been already removed and tested out-of-circuit it seems? Than it's definitelly bad if it reads open.
      • quattro alex
        • Mar 2012
        • 92
        //unrelated:
        Thanks for the heads up on the "switchers" I'll take that heat sink out and test them on the DCA55.
        Yes, I've got it out of circuit to be sure, but it reads shorted rather than open. Thanks for checking
        Fixed so far: GNR TS902W monitor, Sony Game Gear, Philips FCD565, Arcam Alpha 10, Memorex SA 404amp
        • Behemot
          • 4845
          • CZ
          For diode open means shorted. Good diode is closed from one side (unless it's zener), allowing current to pass only in one direction And even in such condition there is voltage drop. Open diode has the P-N barrier broken so it behaves like conductor.
          But not always it just opens - sometimes it burns so hard it interrupts the path internally. Usually LEDs die this way.
          • quattro alex
            • Mar 2012
            • 92
            Replacing the diode at D5 was all it took in the end to get this up and running. Thank you to everyone's input in getting this up and running.
            Next up I have a Corsair 520w that keeps cutting out on the psu tester, and I have a Goodmans Tv with a burnt connector to the backlight lamps.
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
              by sam_sam_sam
              03-31-2024, 02:12 PM
              09-06-2024, 05:59 AM
