Can we do this with no pics?
  • Ashroyer05
    • Sep 2013
    • 162
    • U.S
    My Hitachi would power on, the screen would come on then after 5 seconds or less the screen would go out and then the power LED would flash green repeatedly. I am trying to figure out if it is the main board or power supply causing the issue. I don't have a good camera right now for pics.
    Steps taken:
    1. Disconnected the sustain boards.
    2. Measured voltages from psu to main
    Pin 1. reads constant standby of 3.371V
    Pin 6. On reads around 5.18V
    Pin 6. off reads 0V
    By off I mean when the screen goes out along with the sound of a relay.
    Thanks for any input you may have.
    Re: Can we do this with no pics?
    How about a model number at least? Written on the rear of the set for example P42L01UA.
    • Ashroyer05
      • Sep 2013
      • 162
      • U.S
      Cmp4121hdu
      • Ashroyer05
        • Sep 2013
        • 162
        • U.S
        bump**
        • Ashroyer05
          • Sep 2013
          • 162
          • U.S
          http://www.retrevo.com/pdf/352ci863/...CMP4121HDU-511
          page (39)
          by "flickering" I think they mean blinking which is what it does after the screen shuts back off. It did say it is in "power saver" mode when the display kicked on.
          • Ashroyer05
            • Sep 2013
            • 162
            • U.S
            *page (23)* sorry
            • Ashroyer05
              • Sep 2013
              • 162
              • U.S
              The clicking is coming from around those 2 big caps in the picture.
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • reformatt
                by reformatt
                07-31-2025, 08:37 PM
              • smic717394
                by smic717394
                07-25-2024, 10:16 AM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • spice_disc
                Vizio TV M50-C1 reboot cycle and static on screen
                by spice_disc
                I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                09-08-2024, 02:37 PM
