TO-220 and other 3-pin dual diode modules: common cathode?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8716
    I was looking at a bunch of my TO-220 dual diode output rectifiers, and a vast majority seems to be common cathode - which would be perfect for making forward and push pull converters, and not too had to use both for flyback. But I wonder if anyone has seen many common anode devices, which probably would only be good for flyback?
    I have this ~40W PSU that has extra component holes for extra outputs and was tracing how the unused positions are hooked up, and it would make sense only if this one TO-220 device was common anode (and the cathodes are shorted together externally for a flyback design). Looking at my parts bin, all of them are common cathode...
    Are these really as uncommon as I think they are?
    Re: TO-220 and other 3-pin dual diode modules: common cathode?
    The dual Diode are just that, it can be used as full wave rectifier set up, most SMPS use them as half-wave rectifier setup and just parallel the two diode together. You use Common Anode for the Negative out put. Common part.
    https://cdn.badcaps-static.com/pdfs/...a57ada6ebd.pdf
    http://www.onsemi.com/PowerSolutions...?id=MUR1620CTR
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8716
      Odd, of all the PSUs I've parted they were pretty much all CC... was thinking they didn't make CA - I was thinking the two diodes in series would be more popular than CA...
        Because most of them for the + out put, not negative out puts.
        Here is simple +/- power supply:
        http://www.circuitstoday.com/regulat...supply-circuit
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8716
          Exactly, CA would be best for negative outputs but since rarely do you want a negative output (about all that needs a negative output these days are possibly op amps, and usually even those use so little current and are satisfied by charge pumps) I thought manufacturers did away with CA completely to save money by reducing SKUs.
          Oh well, I guess I need to look for a CA unit for this PSU or modify it to use a CC unit... Probably not worth sourcing a new one.
          • japlytic
            7 segment LED displays: Common cathode vs. common anode
            by japlytic
            With 7 segment LED displays, are common cathode units more common than common anode units?
            From what I see, common cathode units have simpler drive circuitry.
            10-29-2019, 06:55 PM
            Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
            The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
            Securing a good thermal interface between...
            10-07-2024, 04:35 AM
          • ongobongo
            Ram Modules with undderfill - tricks for desoldering
            by ongobongo
            I'm working on another Lenovo E14 gen 2 AMD here which has a ton of errors with the factory soldered DDR4 ram chips. I do have a donor board here from which I'd like to use the modules and swap them. Unfortunately, the modules are glued down with underfill, which i have never worked with before.
            I tried with a lot of heat on the donor board but the modules won't come loose.
            Are there any hint or tricks when it comes to dealing with underfilled chips/ic that could help here
            Ongo
            06-02-2024, 02:18 AM
          • gabrielA7
            Zotac GTX 1080 8GB / No video / Error reported on all memory modules!
            by gabrielA7
            Hi guys!!
            I have this video card on my bench, it turns on and the screen goes black!
            I used MATS but it showed an error in all memory modules, when writing!
            I once got a 1060 with the same symptom, all modules were defective, I rebaled the GPU and it stayed the same.
            Remember that I have all the debts ok, 1.35 Vram and such!
            Could the problem really be in the GPU?
            Could it be the BIOS?
            Thank you in advance!​
            06-05-2025, 09:04 AM
          • J_T
            Operating frequency for motherboard common mode inductor/filter
            by J_T
            I have a question - I have replaced the PSU on my own iMac Pro. However, when removing the motherboard I knocked of a 120 OHM 30% 0.3A small surface mount common mode inductor/filter (~0602 size) in the ethernet circuit near the female RJ45 port.
            The closest match I can find on Mouser is 120 OHM common mode inductor at 100MHz - my question is this frequency correct for a motherboard? The schematic for the motherboard only provides '120 OHM 30% 0.3A' and the TDK part number does not return anything in google.
            Sorry, I am not experienced hence a basic question.
            01-04-2025, 05:54 AM
