Hammax PSU 13.8V Transformer
  • 9w2tzw
    • May 2013
    • 14
    • Malaysia
    recently i got one Hammax 13.8V 30amps PSU which has its secondary transformer near filter capacitor blow.The problem its, the PSU didnt had any schematic available and the blowed transformer didnt had any identification for replacement.Could anyone help me with this problem? I had attached picture of the transformer below.
    Any helps are most welcomed.Thanks
    Learn a Little but Often,
    Practice Makes Perfect,
    Repetition is the Key of Success,
    Re: Hammax PSU 13.8V Transformer
    Is the yellow Mylar transformer wire wrapping show any sign of burn? It looks to me like there was some kind of conductor touched the two pins of the transformer and blown to pieces.
    • 9w2tzw
      • May 2013
      • 14
      • Malaysia
      yeah, i thought so....closer lookup, i found that the transformer wire itself had one of the wire shorted to other terminal.....since i could not get any schematic , transformer reference for replacement, is there any guide to replace it?? thanks.
        The transformer may be OK, you have to use the ringer tester to test the transformer. I can see that the magnetic wires wrapped to the posts/pins are still OK. Try cleaning off the carbon deposit so you can take good closed up pictures of those pins.
        Cabn we see the whole top side and the bottom side of the board?
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Doesn't look good ... probably the switching transistors' driving transformer. Test the switching transistors on the heatsink in your picture. (you can just barely see the heatsink and two transistors mounted on it)
          Muh-soggy-knee
          • learnmore
            Help choosing replacement transformer for Levoit 600S SMPS
            by learnmore
            Hello Community,
            I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
            Peace
            LM...
            11-04-2025, 09:35 AM
          • ohren
            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
            by ohren
            Hello!
            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
            Measured voltages with no load:
            After rectifier diodes
            12V: 6.17 V
            5V: 5.67 V
            Secondary transformer pins AC measurement (really don't know if this says anything)
            12V: 2-2.5 V
            5V: 1.04 V
            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
            03-18-2023, 10:33 AM
          • mikey5791
            Is it possible for transformer substitution?
            by mikey5791
            Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
            Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
            My questions are
            1. How do i test to see if the transformer is in good working condition?
            2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
            Hope you guys understand what i was asking. My intention is...
            11-03-2022, 02:11 AM
          • dennis_elx33
            3PHASE STEP-DOWN Transformer in Check
            by dennis_elx33
            Hello All,
            i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
            Problem statement: Power tripped Off
            Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
            Action Done:
            1) Replaced the faulty parts with good spare.
            2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
            12-02-2024, 06:52 AM
            ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
            This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 04:40 PM
