About series bulb tester
  • senz_90
    • Aug 2013
    • 328
    • Indonesia
    while couple a days, i built series bulb tester based on googling. it built with 62watt bulb. the one i wanna ask about the result is the bulb blinking fastly when i tested it with my psu 450watt that are tried to fixing..i know that when the bulb light for 2-3 seconds and dim after that means that no shorted components anymore. if the light just bright fully it means that still shorted in psu...
    so what is that blinking result means??
    any advice really appreciated..
    for note i just trying fix my psu that has no voltages before, just +5VSB. after found some defective's. it has a voltage agains on rails :
    12v reads about 11.7v
    5v reads about 4.8v
    3.3v reads about 2.8v
    and the black(ground) cable makes a little deflection when my black leads probe touching it? ??
    "There is no shortcut to be successful. No pain, no gain."
    Best Regards
    Rudi
    Thank You
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: About series bulb tester
    my rule of thumb is the ballast(bulb) needs to be the same wattage as the psu outputs, in this case 400watt but thats because i have adapted to using different ways of 'testing' using mainly heating elements, but i don't know what wattage to use for bulbs, by any chance are you using those curly bulbs?
    Follow the white rabbit.
    • senz_90
      • Aug 2013
      • 328
      • Indonesia
      i just think this psu doesn't have real wattage liked written in the case..it don't have filtering coil, Y or X caps evenmore..the bulb that i using is the fluorescent lamp internally ballast usually be used at home. not curly, just like a straight line but it just different on shape i guess..sorry for bad english. heating elements likes element to makes water boils?
      Best Regards
      Rudi
      Thank You
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        yes, the heating elements i used are tea kettles.
        • senz_90
          • Aug 2013
          • 328
          • Indonesia
          how u connect it? would u mind
          give a toughly schematic?
          Best Regards
          Rudi
          Thank You
          • cheapie
            null
            • Jul 2010
            • 849
            That's the problem. Dim bulb testers must use incandescent bulbs. Fluorescent will not work properly.
            For connecting a ballast, just replace the light bulb socket in your tester with an electrical outlet. Then, plug whatever ballast you choose into that outlet.
            However, it does sound like your PSU is not shorted, and would be safe to plug in directly now.
            • senz_90
              • Aug 2013
              • 328
              • Indonesia
              lol. i have misunderstanding about the bulb.. it does means my PSU fine with blinking result from your statement "it does sound like your PSU is not shorted"? i know the bulb that i have used is wrong, but the statement give me some hope to get it back from dead..
              Best Regards
              Rudi
              Thank You
              • cheapie
                null
                • Jul 2010
                • 849
                Fluorescrents tend to blink or not light at all instead of being dim. The bulb lighting constantly in this case would indicate a short, while the flashing is indicating that there is not a short. Also, you mentioned that you are getting output from the power supply. If it was shorted, there would be no output.
                • senz_90
                  • Aug 2013
                  • 328
                  • Indonesia
                  i got it. but my black ground cables has a voltage in rails. strange.. i have checks all diode but there was not shorted..maybe i' ll post my PSU photo to give you some signed that i missing. i just try fixed it myself because i wanna challenge myself to troubleshoot that psu without just asking and get the defective one's without struggles from myself..
                  Best Regards
                  Rudi
                  Thank You
                  • CapLeaker
                    Ancel BA-101 automotive battery tester reads low on flooded batteries
                    by CapLeaker
                    I’ve got this Ancel BA-101 battery tester for a few years now and discovered an issue testing flooded car batteries. The damn thing reads always low compared to other battery testers. I mean low in the tune of 25 to 30%! AGM’s read comparable within margin of error. I wonder if all these have the same problem or mine is defective somehow?...
                    10-20-2024, 09:38 AM
                  • repair-it
                    TOSHIBA DLP 52HM95 How to reset timer module on bulb
                    by repair-it
                    I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                    Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                    10-11-2023, 07:18 PM
                  • DCJack
                    B&K 707 tube tester. I need help.
                    by DCJack
                    Hi everyone!
                    I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
                    Initially I noticed that I was not getting the red on-light to turn on, but it...
                    03-05-2024, 05:05 PM
                  • ezenia
                    LUMIMAN Smart Bulb IC ID?
                    by ezenia
                    I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                    In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                    04-28-2025, 05:56 PM
                  • JimBanville
                    Replacing incandescent bulb on Pioneer LD player with led. Need help :)
                    by JimBanville
                    I have a pioneer dvl-909 LD/dvd player from 1998. It has a light on the front panel that lights up when you play a dvd. I removed the bulb and it appears to be a tiny incandescent bulb. Its measures "open"/dead and the bulb is black like it's blown. The socket it fits into measures 5v. I've looked up the schematics and there's no indication of the amperage. I don't want to spend any money on new parts, but I have a pack of like 100, 3v, 20ma LEDs and I have various resistors.
                    Is there a way for me to determine the amperage going to the old dead bulb with my multimeter?
                    01-24-2023, 07:49 AM
