Fortron Blue Storm II FSP500-60GLN
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    notice untamperproof warranty sticker
    the side exhausts are very effective
    yate loon instead of protechnic. cooling is as expected quiet and good
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Fortron Blue Storm II FSP500-60GLN
    single capxon primary cos its active psu for the blue storm ii. actually i did a double take while looking at the box....
    all the secondary caps are capxon also. its an interesting change for fortron..
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      pcb notes FSP500-60GLY not GLN like on the specs sticker. Anyway they call it "Fortron Green" and it is what the Zalman ZM-460APS is based on.
      i dont think you would need more connectors. it has 2 pci-e also
      last one - specs
      • Galvanized
        • Mar 2006
        • 468
        Not trying to be off topic.
        Here's jonny's review of the new Fortron provided Zalman 600W heat piped unit.
        http://www.jonnyguru.com/review_details.php?id=46
        He feels they changed the platform a bit because the Epsilon based units (OCZ) went out of ATX ripple spec near full load. The Zalman unit load tested very well indeed.
        So maybe this Blue Storm II is built on the same platform.
        EDIT: CapXon are used in this Zalman unit and all the smaller caps in the Zippy's I've opened up are CapXon also.
        • Oklahoma Wolf
          • Dec 2005
          • 353
          I'm just glad to see a recent FSP that doesn't have OST caps on the 12v output
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            dunno but this pcb only goes to 500w.
            here is the 400w Green
            http://www.silentpcreview.com/article280-page1.html
            • gonzo0815
              • Feb 2006
              • 1600
              It is the same GLY PCB like in my Amacrox Free Earth 500GLN. I wish i would have ordered the 550w version, as the higher wattage models are probably based on the Epsilon series PCB wich should be ready for up to 650w.
              All caps are Capxon too, but i have replaced some of them with Panasonic FM 1200uF.
              The only difference i see, the Amacrox does not have 2200uF caps on the 5 or 3.3v rail. IMHO there where only 1000uF 16v KF on all rails. IF i order new caps, i will loock for that, if there are no 2200uF i will change them to that value, as your units seems to proof, that a little more capcitance would not harm. But thois desing is not absolut silent, as airflow is the key to keep this unit cool. Any way, i have replaced the Protechinc Fan with an AC120mm fan, but iam not shure if this is enough airflow, but up to now it seems to be ok.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                Those are rather small heatsinks on the FET's and regulators for a 500 watter.... Compared to the Antec HE550's, which are 550 watts, and have enormous heatsinks... I just thought that's a little odd that the sinks are so small.
                <--- Badcaps.net Founder
                Badcaps.net Services:
                Motherboard Repair Services
                http://folding.stanford.edu/
                Team : 49813
                Join in!!
                Team Stats
                • Big Pope
                  Approved Vendor
                  • Dec 2005
                  • 426
                  Oh, OMG.
                  Is it that 2200uF 6.3v in diameter 8mm?
                  My SAMXON Capacitors Database HERE!!
                  X-CON is a new brand for SAMXON's Polymer Capacitors.
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    yes but old epsilon pcb is not good design apparently. this one gets good reviews as far as i see but of course it hasnt been johnnyGURUed yet
                    same surprise with epsilon design. apparently fortron have designed for less heat, i will see how it goes. i think airflow is good though
                    i will check, i think so. There is some space for recap as they designed for 10mm in those positions.
                    • Big Pope
                      Approved Vendor
                      • Dec 2005
                      • 426
                      Nice to hear that.
                      Fortron is SPI OEM factory, SPI is very famous in the past(P3 age) at our side, but now have many brand of nice power supply for selection here, lol.
                      • gonzo0815
                        • Feb 2006
                        • 1600
                        The PCB is not the problem here for recaping, the cables are.
                        Those small heatsinks are ok, as the whole PSU is desingt to have an unrestrikted, high airflow. The culprit of this desing is, that you can`t get those PSU`s to absolut silent, but on the other hand the noise is lower than most other units. It is mostly the air exhaust itself wich generates the noise. Seasonic and Antec have choosen the other way, wich means large heatsinks and medium airflow. So they can reduce the airflow significantly at lower loads but at higher loads they have the same problems as the large heasinks cause audible disturbances.
                        • Super Nade
                          • Jun 2006
                          • 294
                          In all this, CapXCon caps seemed to have acquitted themselves rather nicely. I have not heard till date of any mishaps related to blown caps on the Bluestorm series. It has been what two years since the Bluestorm was released?
                          Q6700 @ 3.6 GHz
                          Zippy GSM-6600P
                          Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
                          Abit IP35Pro
                          ATi HD4870
                          • gonzo0815
                            • Feb 2006
                            • 1600
                            Well, i would not expect an early failure from the Capxon. I would assume, that they will fulfill their spec.
                            I personaly have not had any trouble with them. Shure, they are not a superspeced ultral low esr cap, but they work. IMHo there is no need for those LOW esr values a Panasonic FM would provides in a PSU. But that dosen`t held me off in replacing them all with FM`s with a little higher capacitance (1000uF >> 1200uF) in my Amacrox.
                            Only the 12v caps where not easy to replace with 10mm caps. therefore only two of four are replaced with 1500uF FM`s.
                            • willawake
                              Super Modulator
                              • Nov 2003
                              • 8457
                              • Greece
                              dammit i thought my main pc was a goner.
                              came back to the house, breaker is tripped, APC ups is on overload alarm
                              now the pc doesnt boot with this bluestorm ii.
                              so i swapped it out and whew that was close.
                              the funny thing is that a bluestorm I in the office "died" recently and stayed dead and i left it then i was checking it for rma and the fucker started working again.
                              wtf with all this?
                              • gonzo0815
                                • Feb 2006
                                • 1600
                                May be i have a similar problem like you with my Amacrox Free Earth 500 GLN.
                                Frome time to time, the 16A breaker automate is tripping, when i switch on my system from stand by (S3 mode).
                                I haven`t tracked it down up to now, as i am using a master slave outlet (switching on some speakers, TFT a portable DVD Burner) and have added some Transil surge protectors to the Amacrox PSU.
                                I if it will happen more often, i will track it down by simply bypassing the master slave box.
                                Any way, faulty APFC circuit would be a prime candidate for this problem.
                                • willawake
                                  Super Modulator
                                  • Nov 2003
                                  • 8457
                                  • Greece
                                  its the same psu isnt it?
                                  this is not common for me though. it has been 100% good since months
                                  i think i will get a seasonic and move this to a less critical system
                                  • gonzo0815
                                    • Feb 2006
                                    • 1600
                                    It is the same PCB and design, but yours is probably the improved one (at least your output capacitors are 2200u, mine where all 1000Uf).
                                    I have it in operation for about one or two years or even longer.
                                    It is still in my main rig, i do have little concern, that it would brake anything there.
                                    • willawake
                                      Super Modulator
                                      • Nov 2003
                                      • 8457
                                      • Greece
                                      well i switched it with the HEC in my media system cos if i want seasonic i have to order and i didnt have time. the Bluestorm II is completely dead
                                      then i took the Bluestorm I from the office and put it in the media system, was working fine for one day. Today the media system wont turn on. whats going on?
                                      visually these units look fine
                                      • i4004
                                        • Oct 2006
                                        • 2029
                                        sounds like sc on primary side of psu.
                                        will you be troubleshooting it?
                                        preserved that warranty sticker?
                                          Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:50 AM
                                          Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-07-2024, 05:00 AM
                                          Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
