Power brick squeezes, low output voltages
    Re: Power brick squeezes, low output voltages
    Yes. Generally a perforation of holes are arranged in a grid or pattern in some way as opposed to a single hole.
    • Behemot
      • 4845
      • CZ
        Looks like a hand grip to me...
        • Behemot
          • 4845
          • CZ
          Oh, you're right after all. I'd swear I've seen light through it, must've been some reflection.
          Anyway, notice that nowadays 120W+ adapters are being made in this size.
            The original Xbox 360 adapter is about 50% bigger and has a 230W output. It does include a fan to keep it cool, and they seem reasonably reliable. I'd say above 120W you're hitting the limit for pure passive cooling. You need active cooling.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Originally posted by Behemot
              I said "perforations", doesn't it mean "holes through the material"?
              Well, you got that one right
              I have never seen an adapter, besides the xbox ones, have holes for cooling. It seems it would be easy to get metal bits, staples, paperclips, liquid, etc inside through the holes - that would be a shock and fire hazard! :O
              Muh-soggy-knee
              • Elysarian
                • Mar 2013
                • 200
                • United Kingdom
                #27
                At £60-70 a pop (new, before discount) we've never considered those PSU's to be worth the engineer time to repair...
                The rule is usually: if it's worth less than 2 hours (charge to customer) then bin it as by the time you've spent the time disassembling and testing you're making no profit and often a loss on the deal.
                • Behemot
                  • 4845
                  • CZ
                  #28
                  I am sorry?
                  I don't think in this case it should be a problem. You see the electronics inside is cased in this aluminium casing and everything from outisde world would have contact with this aluminium cover only. It may not be as resistant to liquids, but if you spill mug full of tea onto ordinary brick, you may as well short it (around the AC plug for example).
                  • Elysarian
                    • Mar 2013
                    • 200
                    • United Kingdom
                    #29
                    I was just commenting on the cost of replacement vs repair on the PSU brick...
                    As for it not having ventilation holes, I can only assume this is to enable it to comply as a class II device (double insulated) - if there were exposed metal parts it would have to comply to class I requirements which would mean the unit would have to be redesigned (to allow the heatsinks to be connected to mains earth) - in the application that this particular PSU is designed for, having a mains earth common to the chassis ground would be undesirable as it adds another possible path for an earth loop to form.
                    • Behemot
                      • 4845
                      • CZ
                      #30
                      This is not ordinary laptop brick, I found new starting at 90 USD without shipping and VAT. My price per hour is much less than that. I will increase the price as I will get more skilled ofc but still it will be some time before such bricks will be cheaper to get new than repair here
                      • Elysarian
                        • Mar 2013
                        • 200
                        • United Kingdom
                        #31
                        I know it's not a laptop brick - it's the PSU for a Dedicated Micros Sprite CCTV DVR
                        I'm a CCTV engineer and deal with these units on a regular basis - they're cheaper where I am as DM are a UK-based company.
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          #32
                          PW is general purpose.
                          No, Nichicon PW is low ESR.
                          You may argue it's entry level, but it's still low ESR. I use them, along with PM and PS for fixing the start-up caps in bricks like that. They use non-aqueous electrolyte and usually have much longer endurance over regular 105C general purpose caps. Panasonic FC is very good in this application too.
                          Also, as far as I know, Chemicon KME is a very old series that is discontinued now and replaced by KMG (hence, I'm not that surprised it failed in that adapter). Not that KMG would have been better in that spot, though.
                          • Behemot
                            • 4845
                            • CZ
                            #33
                            Sure, must have written it the other way around - VZ is GP, PW low-ESR. Btw, where are those posts??
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              #34
                              Post #12, page 1 .
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                Despite hard plastic being a decent thermal insulator, it does conduct some heat, otherwise I wouldn't get condensation on my hard plastic cups when I have an ice cold drink in it...
                                Styrofoam on the other hand is much better...
                                • Behemot
                                  • 4845
                                  • CZ
                                  #36
                                  Originally posted by momaka
                                  Post #12, page 1 .
                                  Oh, I thought it was on this side and somebody deleted it as OT
                                  • FrancescoV
                                    Onkyo HT-R390 no sound output, video output ok
                                    by FrancescoV
                                    Good morning everyone,
                                    I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                    The firmware reported is the following:
                                    M:1.00/11107BLP
                                    D:?.??/????????
                                    O:1.00/11107AL
                                    The DSP firmware given the question marks seems corrupt.
                                    On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                    05-11-2025, 02:59 AM
                                  • gjgib
                                    Help reading schematic voltages input/output
                                    by gjgib
                                    Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                                    I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                                    I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                                    I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                                    05-06-2024, 08:11 PM
                                  • scottsman76
                                    Samsung UA40D5000PR Pulsing output voltages
                                    by scottsman76
                                    Hi Guys
                                    I Have this Samsung smart tv that needs repair.
                                    with everything connected i get pulsing A5V at the PSU connector. if i unplug the main board then all voltages pulse on the output connector.
                                    I dont get any voltage on the LED connector.
                                    there is also an audible click around the mosfet marked below
                                    The connector to the Buttons all voltages pulse (3v)
                                    I have searched and found a similar problem but there was a stable 14v, but was also not repaired.
                                    I checked and replaced the mosfets with no effect.
                                    Any ideas where...
                                    03-30-2023, 10:33 AM
                                  • Dannyx
                                    Modifying power brick output voltage question
                                    by Dannyx
                                    Good day folks. With the joint I work in starving for parts, I use everything at my disposal and stock everything as much as I can. Take this situation: not a single 12v brick around ! Instead, I scrounged up two HP printer bricks. They're rated at 36v 2A, which is useless for anything other than powering the printers they're designed for. What do we do ? Hack them, of course. I did this in the past successfully on a Vaio adapter, with the help of some of our wonderful chaps here, but this one gave me a bit of trouble and I was wondering what I'm doing wrong. I'm aiming for a large drop here as...
                                    06-16-2020, 10:23 AM
                                  • Joekhoe
                                    Sharp Aquos Quattron LC-52LE835X Totally Dead, no output voltages
                                    by Joekhoe
                                    Hello all, I'm Joekhoe, a newbie here and ask your masters permissions and solutions for the problem i'm facing at the present.
                                    I am in the middle of working on a SHARP Smart TV model LC-52LE835X from my customer, which totally dead and there's no output voltages at all at the output pins even though i have replace some of the components the output voltages remain the same with 0 volt.
                                    The replacement as follows:
                                    1. IC7905 : TNY264PN (first found exploded)
                                    2. Q7915 : BT169D (exploded too)
                                    3. IC7901 : 1608B (controller ic)
                                    4. IC7601 :...
                                    09-17-2020, 05:52 AM
