I got this Dedicated Micros VS-PSU65W-EXT power brick. it is supposed to have three output voltages (+5, +12 and -12 V). When I got it, it squeezed and had almost no outputs (maybe some tenth of volt).
It seems there is no real ground rather than it has flying ground, that possible? The +5 V output rectifiers (FMB24L) showed aprox. 40 on diode tester. I took them out, it still shows 40. But I think they were partially opened anyway, showed 96-99 on the internal diodes, good shottkies show around 140.
I have swapped them with MBR20100CT, now it still squeezes but I got something, aprox. +1,8 V, +4,4 V and -4,4 V. All other semiconductors (diodes, rectifiers, one zener) measure fine.
I took out one ceramic cap, thought it may be open, it checks fine, however, now the +5V measures 43 or so against common. There is one other cap, small blue, it may be open maybe? Other than that, I do not know what is wrong. Caps are good, Chemi-Con, all measured good (in circuit). Is it possible the secondary transformer winding is shorted? Or may optocouplers be bad?
Half of the computer problems is caused by bad contacts
was too much in this heat
Ment whistles
