Hi guys,
I blew up my own laptop charger somehow... did hear anything actually blowing, but I opened it up and the fuse, bridge rectifier and secondary schottky diode are all blown.... I only got the laptop as a "test" machine, so it's pretty old and requires 15v / 4amp.
I have a few old 19V /3.42amp chargers that I can take apart and use for bits.. So I'm gonna take the brige rectifier and schottky diodes from the 19v charger and replace the blown ones in the 15v / 4 amp charger... Now this sounds simplistic, but is there any reason why it wont work...There are only two things I'm worried about.
1. There is obviously a difference in the currents, so this is probably the most serious issue.. but the laptop should only be drawing 4 amps on full white screen, with all fans, wifi, everything running, which is not normally the case. So I should be pulling 4 amps through the components, probably closer to the 3.42amp they were designed for.
2. The secondary diodes are designed to rectify 19V DC from the high frequency AC from the switch mode transformer.. Again there is the issue with the current above, but (big disclaimer) if you ignore that then it should be basically rectifying 15v instead of 19v. I mean they are just diodes after all.. But is there a risk that the 19v adapter's dual diodes may not be "fast switching enough" for the 15v adapter.. Is it a big gamble to just say that the oscillator circuits in both adapters work at roughly the same high frequency.
I have a feeling I'm gonna blow something up with this one.. ;-) I will video it and stand back, like the guys watching the Trinity test.
thanks,
J
thanks,
J
