Worth saving ? analyze this psu for me please
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Worth saving ? analyze this psu for me please
    LOL have those caps vented yet?! That thing is toasty!!!
    • Gabriel
      • Jan 2010
      • 620
      • Norway
      Nahh it didn't fail - still working as it should with a steady output.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Try changing the output capacitors with some that have a bit higher esr - say 0.05 ohm instead of the fullcraps' 0.02.
        It should not be getting up to 100C, that is too hot. I kinda suspect the capacitors have too low an esr xD
        Muh-soggy-knee
        • madyoyo
          Samsung QE55Q65B with shorted D001 diodes on panel board: Worth saving or not
          by madyoyo
          Hi
          I have a Samsung QE55Q65B with a seemingly common problem: it turn off and back on after a few seconds, (sometimes more, and in rare instances works for hours). D001 on the left side of the panel is very hot. I may be able to remove it with a very fine iron, but i don't have the equipment to re-solder such small parts.
          Is there a risk to run the tv without this diodes diodes? And is it worth to pay someone else to replace it. I read many people who ended up with bad lines after trying to remove/replace them, , or the panel failing in another way, so i want to weight...
          12-01-2023, 09:28 AM
        • TrueSword88
          KOGAN - KALED58RT9220SVA - Image flickering when in Energy Saving mode
          by TrueSword88
          Hi All
          I have a KOGAN 58' LCD Panel that 'flickers / pulsates' when in energy saving mode.
          I've reset the unit to factory default & rerun the initial setup but no change.
          IF I choose any other mode, example: Standard, flickering disappears.
          I've downloaded the most recent FW for this model from Kogan's website & re-flashed. This initiated a full wipe of the unit, which subsequently led to the setup all over again, however, the issue still remained - screen flickering but only when in 'energy saving' mode.
          I've taken the unit apart,...
          05-05-2023, 06:07 PM
        • ohren
          What problems could this blown cap cause in a Marantz SR5400?
          by ohren
          I'm looking at a vented C513 in a Marantz SR5400 (photo included), in the FR section on page 24 in the service manual (https://audiocircuit.dk/downloads/ma...400-avr-sm.pdf).
          R533 right below it in the photo is charred, but measures the correct value.
          1. I'm not familiar with amplifier circuits (at all — don't know the difference between classes, etc.) so I was wondering what problems would manifest from a supposedly non-operational C513? I didn't hear anything odd when testing the output channel with a speaker. Is there a simple test that can be done...
          10-21-2025, 09:02 AM
          Fintek F71868A Super I/O and Hardware Monitor Datasheet
          The F71868A which is the featured IO chip for PC system is equipped with one IEEE 1284
          Parallel Port, two UART Ports, one 80 port (multi with COM2), Hardware Keyboard Controller, and SIR. The F71868A integrates with hardware monitor, 9 sets of voltage sensor, 3 sets of creative auto-controlling fans and 3 temperature sensor pins for the accurate dual current type temperature measurement for CPU thermal diode or external transistors 2N3906. Others, the F71868A supports newest AMD TSI and Intel PECI 3.0 interfaces and INTEL Ibex...
          10-23-2024, 02:26 AM
        • ipn00tic
          oscilloscope sufficient to analyze all points on a laptop motherboard
          by ipn00tic
          Is this oscilloscope sufficient to analyze all points on a laptop motherboard? PWM of IC and mosfets for example, or detect communication between super IO for example?
          200Mhz and 2.5Ms/s
          03-03-2024, 04:19 PM
