oscilloscope sufficient to analyze all points on a laptop motherboard
  • ipn00tic
    • Mar 2024
    • 7
    • Portugal
    Is this oscilloscope sufficient to analyze all points on a laptop motherboard? PWM of IC and mosfets for example, or detect communication between super IO for example?
    200Mhz and 2.5Ms/s
  • mon2
    • 14713
    Bandwidth is 200khz (NOT 200 Mhz). Do not recommend to consider this instrument. Review the very in depth reviews and details on EEVBLOG on how to select the best value for any such tool.
    https://www.eevblog.com/forum/testge...parison-chart/
    • piernov
      • Jan 2016
      • 4439
      • France
      Way too slow. Need to consider at least a 50 MHz one for example to be able to measure the 25 MHz clocks properly. 100 MHz preferred, below that are generally devices made way too cheaply and buggy.
      • glovecaps
        by glovecaps
        11-25-2024, 04:23 PM
      • Docus
        Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
        by Docus
        Hi everyone 😀,
        I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
        To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
        Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
        1. I already own the exact same model, but its plastic chassis is badly damaged.
        06-10-2025, 04:24 PM
      • Archimedes
        HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
        by Archimedes
        Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
        Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
        Fans are spinning. Blindly could install windows11 and got the device manager...
        07-30-2024, 05:14 PM
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
        ASUS P5GC-MX motherboard recap
        by momaka
        Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
        This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
        So here is what the motherboard looked like with its original caps:
        CPU VRM area up close…...
        01-27-2021, 11:59 PM
