Found a brand new Comp USA PSU
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    One of those old Leadman LP6100's. Still in the packaging and still smells new from the factory, made in Feb, 2002! My initial thoughts before opening it and seeing the POWMAX fan at the rear: After opening it....not as bad as I anticipated
    It's got a full EMI filter, although no MOV's. Shame on you Leadman. It's got four good sized 3A diodes with room for airflow, 680uF JEE input caps, and a single Toshiba K2996 10A MOSFET, not bad....it doesn't use a 2 transistor design for 5VSB which is nice. Decent sized transformer for a 300W. That controller IC next to the primary heatsink is an AP3843B. The 3.3V rail is missing its inductor. Very nice heatsinks, and they feel very sturdy
    Secondary rectifiers: SBL2040CT 20A schottky for 3.3V, SBL3040PT 30A schottky for 5V, and an FET16BT 16A Ultra fast rectifier for 12V. Not bad considering what the label says... Can't find any info on the other 8 pin IC on the secondary.
    All the caps are JEE except three little 1uF 50V caps are JPCE-TUR and one of the JPCE caps is a value I've never seen before! 4.7uF 10V, C30, the one with the cross vent next to the optocouplers (datasheet: http://www.datasheetarchive.com/cosm...datasheet.html )
    The POWMAX fan barely spins and has no rock to it
    Edit: Worth noting that the JEE cap on the -12V rail is bulging despite never being used
  • Sparkey55
    • Jan 2010
    • 1523
    Re: Found a brand new Comp USA PSU
    The last POWMAX that I used in 2004 lived up to its name in flames out the back of my computer.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      1. The 5vsb IS the two-transistor type. That chip looks like a UC3843, for the main smps.
      2. LOL at the bulged capacitor. It MIGHT be possible that the psu was powered on for quality check testing at the factory (just to see if it works before shipping it)
      3. If your gonna fix up this sucker for fun, replace the following:
      • 5vsb circuit with the 5vsb mod
      • Crappy capacitors
      • Crappy fan
      Muh-soggy-knee
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        So I'm confused, the UC3843 doesn't generate the 5VSB, so that transistor just sitting there with no heatsink is? Okay that makes more sense not sure why I didn't catch that
        I know or maybe it was stored in a hot place for a while and just bulged
        I'm not sure yet if I want to just keep it as memorabilia or fix it up. The fan may just need some oil, I haven't checked it yet
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          If you want...
          It is a hacked together heap, though. Look at all the "misplaced" components- doubled up resistors, parts not placed according to their silkscreen markings, a 4148 diode going "cockeyed" from a jumper to resistor, etc.
          Oh "JEE," what can the matter be?
          Also, that transformer will not be happy over ~225W.
          Nice TO-220 MOSFET where a '247 should be! No lock washer, either.
          MOSFET for 5VSB/AUX not heatsinked, the caps next to it will dry out. 5VSB becomes 15VSB!
          I'll bet the leads to the 4 pin CPU connector are #20, not #18.
          Correct and correct.
          It probably swelled up all by itself.
          • Crappy capacitors
          • Crappy fan
          • Entire power supply
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Yeah I did notice all the misplaced components. It is a Leadman afterall
            225? Seems a little low for the size of it.
            Yeah instead of a 247 they just bent the legs to fit ha ha
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              Now that I've looked a little better at it, you might be able to get 300 out of it. I'm used to the smaller transformer that Pow (to the) Maxes usually have.
              Wasn't there a Leadman that dumped primary voltage into a motherboard a while back? Poor transformer construction or random wire clippings? I would've loved to "autopsy" that one!
              EOL it...
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                IMHO, the fact that there is a TO-220 device there doesn't mean a thing, depending on how the PSU is designed, it could be perfectly fine
                I bet the 5vsb transistor will fry before the capacitors do, that transistor probably has to dissipate around 2-4 watts! With no heatsink!
                Muh-soggy-knee
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3113
                  Yes, the UC3843 is the controller, and that transistor sitting there without a heatsink is indeed for the two transistor 5vsb circuit. It looks like there is a separate 8 pin IC for the protections on the secondary. Most likely 12v and 5v OVP and OCP, and SCP.
                  If you don't want it, I would gladly take it off of your hands. I, for whatever reasons, like to keep some examples of some of these smaller manufacturers units. Leadman units aren't that rare, but these older units are a bit harder to find.
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Really?! I would love to autopsy that thing too
                    You're right especially since it has that good sized heat sink all to itself. If I decide to do anything, I will add a heatsink to it, even a tiny one would help it out quite a bit, those old two transistor designs seem to create a lot of heat!
                    I couldn't find much but that IC reads ST1412A. I would be surprised if it had OCP.
                    I agree, these small manufacturer PSU's are pretty cool because they aren't common and when I saw this one in the packaging for $7 I couldn't pass it up but if I decide to get rid of it you will be the first person I contact!
                    • Wester547
                      • Nov 2011
                      • 1268
                      • USA.
                      TO-247/TO-3P packages dissipate heat better because they cover more surface area of the heatsink. That being said, depending on the type of heatsink used and how the rest of the PSU is designed, that might not be a problem. Some 80+ PSUs have gotten away with using TO-220 switchers without the metal tab so I'm not contesting what you said either.
                      Leadmans are indeed garbage, in fact they're some of the worst junk out there so unless you really want to refurbish it I think it merits scrapping.
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        Honestly I think that this is better than some of the newer flyback converters that Leadman has been making with those T heatsinks that look like they were made from beer cans, and ZERO filtering caps on some of the major rails, completely unacceptable! At least this would be usable in a low end 5V heavy design back in the day (Although those JEE caps and the transistor with no heatsink would die quickly)
                        • PeteS in CA
                          • Aug 2005
                          • 3581
                          • USA, Unsure of Planet
                          TO-247 and TO-3P also have better thermal resistance from junction to case, and can accommodate a larger die. Price-wise, TO-220 is cheaper.
                          PeteS in CA
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            have not seen a leadman unit worthy of anything but use as a rifle target.
                            • Pentium4
                              CapXon Be Gone
                              • Sep 2011
                              • 3741
                              You know it's sad when even the average Deer is better than a Leadman (Although not the one I'm about to post in the gutless hall of shame!)
                              • everell
                                • Jan 2009
                                • 1514
                                I still have my CompUSA 250 watt power supply
                                https://www.badcaps.net/forum/showthread.php?t=8337
                                Mine had all Rulycon capacitors, nearly all bloated. As somewhat of a joke I replaced all of them with Fujiyu pullouts from old Antecs. Far as I know, none of the Fujiyu caps have failed yet and the psu still works. I removed the two transistor 5vsb circuit and installed a DM311 mod. However.............the 5vsb transformer is so small it gets VERY hot when load testing. Might be good for one amp, but not much more! I have never found another 5vsb transformer with a similar pinout.
                                I am somewhat jealous when an old CompUSA Leadman can get so many responses and such loving attention.....They are such terrible crap. HiPro and Bestec are so much better.
                                Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                                • Pentium4
                                  CapXon Be Gone
                                  • Sep 2011
                                  • 3741
                                  Lots of info in that thread, awesome.
                                  Wow, no choke or inductor for the 3.3V? That is embarrassing. I think it's safe to say that even JEE is a step above Rulycon, how long did it take for them to bulge? It also looks like they sliced off the top of your heatsinks, I wonder why.
                                  Only 1A out of that transformer? Ouch! The 250W and 300W look to use the same size one too
                                  Nice mod btw... I agree Bestec are much much better. I love working on them but the glue drives me insane sometimes
                                  • Behemot
                                    • 4845
                                    • CZ
                                    I don't think 3 A primary diodes would be enough for 60% efficiency at 300 W and 115 V AC. Just that nobody mentioned that…
                                    • Pentium4
                                      CapXon Be Gone
                                      • Sep 2011
                                      • 3741
                                      You think the efficiency would be that low? lol
                                      • Behemot
                                        • 4845
                                        • CZ
                                        Such things with ultrafast(s) usually don't go over 70 %, it's somewhere between 60-70 % usually.
                                        • прямо
                                          Viper22A 5VSB circuit
                                          by прямо
                                          So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                          In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                          01-13-2024, 07:05 PM
                                        • kotel studios
                                          FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                                          by kotel studios
                                          Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                                          Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                                          I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                                          Any ideas where to go next?
                                          02-23-2025, 11:47 AM
                                        • mrcliem
                                          CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
                                          by mrcliem
                                          Hello...
                                          I got my self a dead CM V700 PSU, with nothing on +5vsb
                                          I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
                                          As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
                                          The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
                                          I have read the datasheet and and still can not...
                                          06-29-2023, 08:18 AM
                                        • socketa
                                          Zalman ZM500-GV stops after 40s and 5VSB drops to 2.5V
                                          by socketa
                                          Rescued this one
                                          Started it up in the computer case, and noticed that it would shut down after about 10s in the BIOS
                                          Took it out, connected to hard drive and it loses all power on all rails (except for 5VSB) after about 40s or so. (the same result happens without a hard drive connected)
                                          The 5VSB drops to 2.5V when it 'shuts down'
                                          And the voltage across the primary cap falls from 335V to 330V at the same moment
                                          I think that the 5VSB is regulated by an A6069H PWM chip (which was initially dropping to 2.5V even before the the PS-ON was grounded - but it now stays at...
                                          12-20-2022, 03:06 AM
                                        • hobostove
                                          Corsair RM1000e - Help identify 5VSB Zener diode
                                          by hobostove
                                          Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                                          Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                                          There's a 22ohm resistor that's melted and open, but it still has the bands.
                                          The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                                          It looks like the diode connects the source and drain of a TNY284...
                                          03-27-2025, 02:25 PM
