Help with PSU design - 2Kw unisolated Buck
  • Vectrix150V
    • Jun 2013
    • 22
    Re: Help with PSU design - 2Kw unisolated Buck
    Well, I was going to post some more measurements but I managed to kill the UC3842 again - sigh.
    Time to buy some more.
    It is (was) stable at about 300mA, with a 0.47R current sense resistor. I ended up using a very similar design to the one on the front page, but with a 15 K resistor in series with pin 2, so the gain of the error amplifier would be fixed at 10 (with the 150K from comp to VFB).
    The frequency was 100Khz (15K and 10nf for Rt and Ct) with a 270uH inductor and a 200uF capacitor on the output.
    I had a 10nF cap across the opto pins as well.
    Very tempting to move to something like the NCP1216 - fixed frequency, pulse skipping, internal ramp compensation, 250us current sense blanking and 500mA totem pole drive, and direct optocoupler connection.
    • Vectrix150V
      • Jun 2013
      • 22
      Whilst thinking about the lowside buck topology, I considered how on earth someone would perform output voltage monitoring in a buck PFC - I remembered the UCC29910A (that I could never lay my hands on GRRR) and had a look through the datasheet.
      Lo and behold - they use a level shifter (on page 10 - of https://cdn.badcaps-static.com/pdfs/...6fea22c9c4.pdf) so I can toss the optocoupler and the TL431 that are proving to be a major PITA in my design, and monitor voltage directly. At least I can compensate normally with this design, and cull the parts count down even furthur (and not have optocoupler degradation, drift and failure to consider).
      Isolation is not an issue, the output is unisolated, the opto was a cheat because I couldn't think of anything else to do the job.
      Time for more parts, and a redesign of the PCB to incorporate this - fingers crossed.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        That's a good idea. The key to any circuit is to make it as simple as possible, and avoiding an opto and TL431 when you can is a good idea. Good luck.
        A working TV? How boring!
        • Bartoloni
          Lenovo S145 -15iwl vcore inductor warm.. looking with oscilloscope there is a spike.
          by Bartoloni
          Hi, i have a Lenovo S145 that after 20 seconds shutdown and restart (it's working correctly on thse 20 seconds)
          everything seems ok, but on Vcore inductor ( this is an i3 with just 1 switching power supply for CPU)
          there is an output to teh CPU with a spike.. seems that inductor can't handle the input...
          replaced the capacitor (330) and the inductor (R15) without any change
          any idea? very thank you!
          input of the inductor seems as usual... only strange thing is that the upper/lower voltages seems to be 21V (main power line is 19.3) ... but not sure this...
          12-09-2024, 12:42 PM
          Corsair CX750M [Model 75-002019] - burned output toroid inductor
          by momaka
          Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
          So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
          09-19-2021, 08:44 PM
        • mikkele86
          Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
          by mikkele86
          hello.
          I have two power amplifiers, both having their IGBT blown on the PSU.
          The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
          I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
          I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
          So I though i missed a capacitor or diode. I removed...
          01-06-2024, 06:45 AM
          Acer TravelMate TMP215-53-340V Notebook P2 Specification for Upgrade or Repair
          This specification for the Acer TravelMate TMP215-53-340V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TMP215-53-340V boardview and TMP215-53-340V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
          09-07-2024, 05:00 AM
        • badcap111
          How to read inductor specs?
          by badcap111
          I have a broken samsung galaxy s10 with missing inductor. I want to replace the missing inductor and I have found some vendors. But I don't understand how to read the specifications of the inductor. The specs are:
          INDUCTOR-SMD;470NH,20%,2520,T0.8,0.029OH
          I understand that the inductor is 470 nH with 20% margin, and the size is 2520 or 1008 (imperial measure), but what do T0.8,0.0290OH mean? I can't find any explanation on the web.
          09-12-2023, 01:25 PM
