Dps-240fb
Re: Dps-240fb
ok, i will replace it tomorrow.
please tell me if I can replace the capacitor that i mentioned that sparkles with an ordinary electrolytic or really needs to be that little capacitor. (this one is crumbling)Last edited by rtstorm; 07-03-2013, 07:34 PM....the quieter you become the more you are able to hear...Comment
Re: Dps-240fb
The little capacitor there is just for filtering, there should not be any noticeable difference with it removed. If the lamp test passes (lamp glows only briefly), then try it without the bulb.
The PFC chip is likely not bad, that capacitor got stressed and shorted out.Muh-soggy-kneeComment
Re: Dps-240fb
Careful here. When the PFC MOSFET shorts, it will backfeed rectified line voltage to its driver, which happens to be inside the UC3818.
As to the discolored area near C16 on the riser: this is right behind the PFC inductor on the PS main board. As usual, such inductors are undersized (both copper and core) and run hot. They sometimes develop shorted turns, which destroys the PFC MOSFET.
Or, the PFC output cap (330-820u, 350-450V) gets high ESR or opens. Now, the energy stored in the PFC inductor has no place to go. The boosted B+ voltage rises when the PFC MOSFET shuts off (dI/dT) and keeps rising, until the PFC MOSFET, and sometimes diode, are destroyed. At this point the line fuse is blown, the gate driver has been backfed, and NTC (if present) is cracked. If unit is overfused, the line rectifier can short, too. This can all happen before the SMPS PWM even starts!
I stand firmly by what I said on this forum a few years ago- that these PFC boosters were shoe-horned in, like a lousy afterthought. "Just make 'em with PFC, who cares about the horrible efficiency.""pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!Comment
Re: Dps-240fb
i try to remove 20N60, and bulb did not light up. Then i found some little piece of soldering on board, i think that make the trouble. i remove it and bulb light just for sec and then go OFF. I put back 20N60, and still bulb did not turn ON. But i see some sparks on this capacitor in the picture. The sparks are very small. I remove him and he was 1.56nF. And below capacitor i found some burned areas.
The MLCC capacitors are easily damaged, which probably happened when the supply was taken apart.
As for the dark spot, it could also be from that array of resistors on the bottom of the board.
Of course, yes, the PFC controller chip could still be damaged, but using the lightbulb test and measuring the voltage on the big capacitor will tell us if it is working or not.Last edited by ben7; 07-04-2013, 06:20 AM.Muh-soggy-kneeComment
Re: Dps-240fb
I dont think you need to replace it, it is just used for filtering, being connected right under that bridge rectifier. I highly doubt there will be any problems with it removed.Muh-soggy-kneeComment
Re: Dps-240fb
I try it and it is OK, no light turn ON. I try without dim bulb, and it is OK. I try to connect green + black but PS did not turn ON. I check big capacitor and it has 328V DC....the quieter you become the more you are able to hear...Comment
Re: Dps-240fb
what is the voltge rating of the big capacitor?Muh-soggy-kneeComment
by wnlewisOK. I got the rocker switch figured out thanks to the good advice on this forum.
Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
This is a Whirlpool RDE3340 electric range.
The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
Where may I find parts... -
by mikey5791Hi to all forum members,
Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor... -
by emeskayWe have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...1 Photo
I currently have a customer's vintage fan on the work bench to repair.
It uses an induction motor with 4 poles. One of the poles is open.
I couldn't find the break so i cut off the original wire.
I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
The enamelled copper... -
by sam_sam_samI was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap... - Loading...
