ATX power supply
  • newtothis
    • Mar 2013
    • 1556
    • england
    ATX power supply
    I have a Corsair TX650w ATX PSU that had gone BANG!
    Checked the circuit side of the PCB and found a nice black patch, a SOT23 Transisitor had blown and also took out an SMD 20ohm resister on the secondary side. The primary side fuse had also blown.
    I replaced the SOT23 package, resistor and fuse... everything else looks ok, seems to test ok and have good continuity throughout the board.... Problem being that every time i try to test this supply it blows the fuse at the plug as soon as it is switched on.
    Any ideas to what it may be?
    I will post some pictures soon
  • mariushm
    • May 2011
    • 3799
    Re: ATX power supply
    Check the mosfets and parts around what blew up... something may still be shorted in the psu making the fuse blow,
    • cheapie
      null
      • Jul 2010
      • 849
      If it is in fact one of the switchers that went, it may have killed the other one as well.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • Babbar
        by Babbar
        04-12-2024, 01:12 AM
      • vletr
        Edac/Drobo Power Supply Fuse
        by vletr
        Looking for next steps on troubleshooting for an external power supply made by EDAC, model EA11011H-120. The power supply was dropped onto a tile floor and initially and briefly worked but the led power indicator light faded out and the power supply showed no signs of life since.
        In disassembly, I found that the large capacitor had leaked and was reading open when measured. The fuse nearest to the AC in had also blown, with no continuity. I ordered a new capacitor and fuse and replaced both, but on power-up with no load the fuse immediately blew.
        05-25-2023, 07:15 AM
        07-01-2024, 06:34 AM
      • corrize
        A funny fuse story – Lumix LX100 II
        by corrize
        Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
        I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
        The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
        There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
        And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
        10-19-2023, 09:58 AM
