Passive PFC
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Passive PFC
    Never really learned much about PFC so I want to start with the basics...Can Passive PFC have any effect on how much power the PSU can output? Can the higher PF increase the efficiency at which the bridge rectifies the current or is that solely based on the output rectifiers?
    I thought PFC was just to reduce the extra noise that a regular input filter can't get rid of, preventing less interference on the mains voltage. For a regular old PSU with the spot for it on the PCB can you just solder on a PPFC coil and call it good or is it completely integrated into the design of the PSU?
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: Passive PFC
    Passive PFC improves upon "power factor" - the amount of power the power grid thinks you're using, which is different than the amount of power you're actually drawing from the mains. It does result in more heat losses and often I see it implemented in such a way that it might impede airflow to the parts of the PSU - it is heavy and often a huge inductor. What it also helps though is the possibly high (or compromising) currents in the AC waveform/line voltage by way of many computers drawing high peaks, but Active PFC works to the same effect. It -might- also reduce or at least smooth the peak currents and spikes in the transformer and maybe some of the other components, but I could be wrong on that. I personally prefer PSUs without Passive PFC to maximize the amount or airflow available.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Re: Passive PFC
      Oh interesting...They do tend to block a lot of airflow. Seems pretty pointless then, might as well have Passive or none at all
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Re: Passive PFC
        I meant "might as well have Active PFC or none at all" whoops
        • Wester547
          • Nov 2011
          • 1268
          • USA.
          Re: Passive PFC
          Active PFC can be a problem as well depending on the brands used because the primary capacitors are quite a bit more stressed and in some designs that are crappy enough the APFC coil (if cheap enough) runs so hot that it tends to fry everything around it, including itself (a badly enough designed APFC circuit can run hot enough to kill Panasonic primaries), though if the APFC transistors aren't hot they should be okay. There are advantages, such as better use of the power grid and not having to worry about the voltage selector, and the higher voltage and frequency of the whole circuit (the more sinusoidal current means less AC ripple but of course the higher voltage still means more stress...), which helps (though the heat losses of Passive PFC are actually less, so it's more efficient in power factor).... but I personally prefer the simplicity and less stress of the voltage doubler + more airflow for all the components, and not only that but more room for airflow to exhaust heat out of the computer as a whole (or rather extra means to do that besides possible case fan[s]).
          • severach
            • Aug 2007
            • 1055
            Re: Passive PFC
            80Plus ends all that. There's no way a power supply burning up Panasonic capacitors can snag an 80Plus certification. My 80Plus Gold supplies don't have many places they can leak heat.
            sig files are for morons
            • Davi.p
              Reduce the size of photos please..
              by Davi.p
              Hi all, i'm asking all to reduce photos to a more comfortable resolution before post, the better like around 2000x2000, otherwise many PC / Tablets / phones refuses often to load them or has strong defection... today's digital cameras integrated in phones especially are a mockery because them saves photos at enormous resolutions with much less the real definition, so reducing them is only a good deal.. THANKS!!...
              05-16-2024, 12:53 AM
            • corrize
              Tips for reduce shaking ?
              by corrize
              Hello, I have a little problem. When I use hot air, I'm shaking a little with tweezers, and I'm scared to push a little qfn for check if it floating. So sometime, I prefer to not try and « hope » the solder is done.
              I use the blue tweezers mechanic AAC-14 and a I put just my fist on the table.
              Do you have tips to reduce shaking pls ? Maybe shorter tweezers, or something for wedge the fist or arm ?
              (I add : no coffee, no alcohol and I don't smoke).
              08-31-2023, 08:56 AM
              Battery Hookup has a Labor Day Weekend Sale 20% off of regular price which in my case covers the cost of shipping
              I have been looking at some battery packs that they recently brought in and I was debating whether to buy them because of cost of the shipping especially one of the two battery packs that I had bought from this sale that they have going on right now
              https://batteryhookup.com/products/1...44780299845794
              bought one of them
              https://batteryhookup.com/products/3...ttery-with-bms
              bought two of them
              I posted this sale in case someone else is interested buying...
              08-31-2024, 05:06 AM
            • edugimeno
              Grundig 39 WCP 2014 BRS. Bad BL, hack or fix?
              by edugimeno
              Hi! I was given this TV. It would turn on fine but then after a while the BL would shut off while rest of functions would stay working. I assume this 99% means a shortcut in the BL so the PS detects the overcurrent and shuts off the BL pwr.
              I managed to keep it up for the time enough to enter into settings and turn down the backlight to 50% which seemed to help. I was able to watch it for some hours several days
              But the other day, I went to try it and the BL didn't even start at boot up. I want to repair it but: This is a spare TV that I want to keep at a house that I seldom...
              06-03-2024, 12:58 PM
            • odonono
              Louis Rossman style repair shop for regular laptops?
              by odonono
              I made a post over on reddit about how my windows laptop only works when plugged in now, because I dropped a screw driver on the connector pins where the laptop battery plugs into, causing sparks. I put a brand new battery in but still the same result, so something on the board obviously got fried (however, there's no visible burn marks, so no clue what was affected). I honestly wouldn't care, but my laptop is power throttling even with the internal battery unplugged (turns out this is a common problem on laptops with poor batteries or missing batteries). The GPU won't go above 40W when the TDP...
              03-06-2024, 07:31 PM
