Coolmax shuts off after a few seconds
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    I got this thing cheap brand new and decided to recap it, so I did. When I plug it into a computer, it gets stable 5VSB but when I hit the power button it will turn on for about 2 seconds and then shut off. When hitting the power button again it will not turn on until power has been pulled and the PSU is plugged back in. When it powers up for that 2 seconds, the 12V reads ~12.16V every time.
    I can't find any shorts....although the soldering side looks bad (including mine ) Any ideas? I would appreciate any feedback! Let me know if I need to take some better pictures.
    (Side question) On the 12V it has two 16A schottky's in parallel but it has no shunts and only one group of 12V wiring, does this mean that it will only work as a single rail @ 16A but will be more efficient than just one 16A shottky?
  • 999999999
    • Sep 2006
    • 774
    Re: Coolmax shuts off after a few seconds
    Is this happening powering a load or unloaded, and how much load? I'm guessing too much or too little load on the 5V rail.
    Two schottkys in parallel can't be assumed to provide 100% of their summed current, but would be more efficient under 16A AND will allow higher than 16A. One will inevitably have a slightly lower forward voltage than the other and pass more current but this will cause it to heat up more, raising the forward voltage till there is (not an equilibrium but still) a reasonable sharing of current between the two. It's unlikely they will be the bottleneck on 12V current though you didn't mention the (probably false) specs Coolmax gave the unit.
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Thank you for the informative response, Coolmax claims 26A on the 12V. My test machine is a Pentium 4 Prescott @ 3GHz, 2 RAM sticks and a CD ROM drive so maybe you are right and there isn't enough 5V going through it, I will try plugging in some hard drives
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        You, sir.....were spot on! We have life So I'm guessing there was too low of a load and the 5V sky rocketed and tripped the OVP?
        • 999999999
          • Sep 2006
          • 774
          Yeah, seems that way. Too low for their cheap design. I suspect they probably use higher ohm value dummy load resistors trying to make their cheap original caps last longer by removing some of the heat they create.
          Glad you got it sorted out.
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Yeah I was thinking about removing them. The original caps were Gold Link and CS...I doubt they would have lasted long
            • riko 656
              Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
              by riko 656
              I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
              Laptop Model:
              • Model: Lenovo Legion Slim 5 16APH8
              • GPU: NVIDIA GeForce RTX 4070
              • Main BIOS chip size: 32MB
              • VBIOS chip size: 16MB
              Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
              What I Have Tried So Far:
              1. I
              11-04-2025, 05:14 AM
            • chaos-theory
              Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
              by chaos-theory
              I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
              Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
              03-14-2025, 05:37 PM
            • riki_22
              ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
              by riki_22
              I’m working on an ASUS B5402CEA notebook.
              B5402CEA_MB_R2.2
              HA4YT LA-L861P
              REV:1B
              The board powers on, fan spins for a few seconds, then it shuts down by itself.
              I suspect the BIOS might be corrupted.
              Could someone please check and clean (repair) the attached BIOS dump?
              I’ve also attached a few photos of the motherboard for reference.
              Thanks in advance for your help!
              11-03-2025, 04:38 AM
            • APOPAP
              Panasonic National NV-M3 VHS Camera shuts down after some seconds
              by APOPAP
              Hello everybody,
              First post here. I have been reading posts here for some time now, but today I made my first account and post.
              The same question is also posted on another site, here it is:
              Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
              I tried connecting it to a Computer PSU (12.7v) but I get battery error...
              08-25-2025, 10:12 AM
            • tec3000
              Sony LED 65X9005A shuts down after few seconds - looking for help
              by tec3000
              Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
              I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
              03-20-2024, 07:29 AM
